SOURCE: Jabra BT205 connection
you need to hold the power putton some seconds longer when you turn it on, until it starts blinking in an other pattern...
SOURCE: I have lost instructions from my Jabra BT250 and
switch off jabra. Hold down on/off button for sabout 10 secs until blue light is continuously on. Then pair from the phone. Pin 0000
SOURCE: I have a jabra bt250. I put into the charger one
A search on here will get the answer I found it once it. is the battery and headset needs to be opened and 'jumpstarted' it is non replaceable though.
SOURCE: how do you turn off vibration on jabra bt250
Check the Jabra support site for the manual.
It is a simple hold the volumne up when switching on and then if you want to renable it hold it down when switching on.
[or the other way !!] but that is all.
SOURCE: how do i pair my jabra bt250 to my htc desire hd
Connecting a Bluetooth headset or car kit
You can listen to
music over a Bluetooth stereo headset, or have hands-free conversations
using a compatible Bluetooth headset or car kit.
It's the same procedure to set up stereo audio and hands-free.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon
is displayed in the status bar. Depending on the type of headset or car
kit you have connected, you can then start using the headset or car kit
to listen to music and/or make and receive phone calls.
Testimonial: "thanks for all your help all up and working."
