SOURCE: AT&T 974 corded phone
if your dsl is on the same line it will mess up micros for intercome system. Move dsl to another line
SOURCE: AT&T 1487 Cordless phone: the mic is not working after I opened.
Your fix for the non-operating numbers on the touch pad WORKED! I have now developed another problem which I posted on Jan. 11, 2009.
Thank you for all the help!
Peggy
SOURCE: Static on Cordless Phone after Power Outage
First try plugging the unit in and out a couple of times. If that doesn't fix the problem then check the battery packs on the phone units. BTW I meant to plug and unplug power to the base unit. If these solutions don't work then most probable cause is an audio component failure due to the voltage surge on power up. This is normally when most electronics will fail. Hope this helps.
SOURCE: Explain how to retrieve messages
Messages aren't stored in your phone, they're stored in your account. You need to call your phone provider.
