SOURCE: photo copier
Please confirgue the print server properly. Assign a particular ip address to it if possible. Then install the photocopier driver in computer and add the network port ip eual to the ip of print server. if it does not work install the print server driver if comes with it as a printer and assign it a ip.
SOURCE: Printer prints multiple pages with DPR1260 print server
hi dear,
you have to see, When you give the print command how many pages are set to print in printing option of the page and you told about test page, it set to one as default.
SOURCE: Need to install network printer to DLink Router
- First, you have to make sure the Printer you were attempting to install is in range with the LAN IP Address of your D-Link router.
- Second, You have to run the Add a Printer Wizard.
SOURCE: IOGear multi-function USB print server
The direction of the GMFPSU01C will never tell you that you need to create another printer driver. Because, once you install the MFP Utility of this print server, you will have an automatic Copy1 icon of your printer once you successfully, detected the print server and once you successfully connected to the Printer.
Since, the computer is not detected the printer on the network, here are the things that you may do:
1. Make sure that the printer driver is properly installed in the computer. and make sure that the printer is working when directly connected to the computer.
2. If you can't detect the printer, disable your FireWall or any anti-virus program that's running in your computer.
3. Uninstall/reinstall the MFP Utility. If the CD is not working correctly, use the driver from the Website. Here's the link: http://iogear.com/support/dm/driver/GMFPSU01#display
SOURCE: I have print server d-link
Hi, to make sure your printer is online. Please do these steps:
? On your windows 7 computer, please go to control panel and click printers and faxes.
? From printers and faxes, you can see your printer icon, right click the printer icon and select online.
? Try to print and that should be working.
