Cars & Trucks Logo
Posted on Nov 05, 2010
1984 Nissan 300zx non turbo VG30E engine wont rev over 2000 rpm It idles at about 500 rpm with engine warm. When I accelerate the engine at 2000 rpm it starts to skip almost like a rev limitor would do.
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 10 Answers
  • Posted on Dec 05, 2011
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
10
Questions
0
Helped
3617
Points
10
SOUNDS LIKE THE AIR FLOW METER, CHECK THE CONNECTION FOR STARTERS, IF ITS GOOD, THEN CHECK CODES FROM ECU
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 19, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1230
Points
My vg30 dnt rev more than. 2200
  • projectcrxf2 Aug 15, 2011
    i have a 1986 nissan 300zx non turbo and it wont go any higher then 2500 rpms but when i try to drive it once it hits that 2500 it cuts out and sounds like it wants to die
I just bought a 1996 Nissan 300 zx non turbo 5 speed and it won't idle. But when you put it in gear it will idle at like 2000 rpms or if you turn the heater on it will idle at about 1200 rpms. I
Try twinturbo.net. plenty of 300zx enthusiasts and info on that site. Has a tech forum and links to faq. Look around and search. I go there for help on my 93 Z. And no, it doesn't have to be a turbo model.
2answers
I have a 1993 300zx twin turbo that's heavily
you are SURE you have enough fuel pressure? like 60?
2helpful
I have a high idle on my Nissan 300ZX what could cause this?
I have a Nissan 300zx twin turbo 1990.... The engine and car are in very good condition ... well serviced... The idle speed will not go below 2000 rpm can you help as there is no manual adjustment...????
Idles great like brand new. give it throtle and trys to die
ck your maf sensor. The first sensor out of the air cleaner. It controls Air/ fuel ratio. Good Luck, Ned
4helpful
I need the piston firing order for a VG30E or a VG30ode
My sincere apologies for the extremely delayed response.
I am personally going back to answer your unanswered questions.
I have only been a free contributor to this site for the past 4-months.
I do not know if you still need this information, but I am going ahead and answering it anyway.
1. Non Turbo =VG30E. Turbo = VG30ET. In any case the Engine Cylinder numbers, Firing Order, and Distributor Connections are the same.
For the 3.0L:
Firing Order:
1-2-3-4-5-6
Cylinders:
(back of engine)
5--------6
3--------4
1--------2
(front of engine)
Distributor:
....(back)
.6......5......4
V......V......V
1.......2.......3
....(front)
2. I am not sure what what "cam adjustments" you were looking for. I am sure you probably have taken care of that or found what you were looking for. However, in most cases the person is really asking about the Timing issue.
Click on the following Link for the Timing Belt/Chain Diagrams.
Again, my sincerest apologies:
http://www.2carpros.com/car_repair_information/year/1988/make/nissan/model/300zx/1988_nissan_300zx_timing_belt_diagram_marks.htm
Initial Idle problem with 1984 300zx turbo automatic
it almost sounds like the ctankshaft positioning sensor
2answers
Loss of power at 2400 rpm's
Check your mass airflow meter. If it's bad, at least on my 1990 300ZX, the car won't rev over 2400RPM (it's a safeguard built into the ECU of the car). Grab one from a scrapyard and swap it in and see if that fixes the issue.
1helpful
1984 nissan 300zx turbo 50th AE
it is adjusted by the idle screw on the aac valve located on the plenum
2answers
Nissan exa 85
hows the engine mounts? did anything happen leading up to this problem?
Top Nissan Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Nissan Expert? Answer questions, earn points and help others
