Aroma ARC-717G 14-Cup Rice Cooker Logo
Posted on Nov 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have rice cooker i cant cook rice.i am on the cooker 5minute going tourn off
Anonymous
Level 3:
Genius:
  • Master 1,672 Answers
  • Posted on Nov 07, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1672
Questions
0
Helped
462266
Points
5030
U mean, the rice cooker turns OFF after 5minutes?
Sounds like THERMAL adjustment needed!
1helpful
What is the rice to water ratio for cooking rice in the rice cooker?
Here's a simple one page guide for cooking rice in a rice cooker. It will tell you how much water to add depending on the type of rice you're cooking - How to cook rice in a rice cooker
tip
How much Rice and Water go in the Cooker
So you lost the instructions to your rice cooker and now you want to know how much rice and water you need in there…
He is what I have found out with using my cooker to prepare rice.
There is a cup that comes with your rice cooker that equals about 2/3 of a regular measuring cup...one of these or 2/3 cup for every cooked cup of rice that you want to end up with... Add as many 2/3 cup fulls of rice as the number of full cups or servings that you want to end up with. See my notes about washing the rice further down in this tip.
The water...
There are lines on most of the cookers with numbers that represent the number of cups you are cooking...fill with water to that line....
If you are not sure, just fill with water a bit over the top of the rice...the amount is not that critical as the cooker senses when the water is cooked off and then shuts down...so a bit more will only make the cooking time a bit longer... no biggee...
Also it is best to rinse your rice before you actually leave the water in the pot that you are going to cook with...
Remeber also, if you have a brown or wild rice setting that the cooking times are MUCH longer...like up to 90 minutes, so get it started in plenty of time or you will be eating rice for a snack before bed...
The best feature is that you just have to place the rice and water in the unit, press the button for the type of rice you are using and forget about it itll it goes through the cycle and shuts down, going into the hold warm mode....it is so easy!!
These things are really goof proof, and make great rice very easily...a little bit of experimentation and you will enjoy very much using your rice cooker.
Info needed on rice cooker Bravett model MC665H, how rice can go into pot, what type of rice, and how long to cook
A cup of rice is equivalent to two person, depends how a person consumes the rice.
First wash the rice by rinsing it two times( using the pot itself ) with fresh water, add water till it cover the whole rice, amount of water should not exceed the level of your first line mid finger. After that put it in your rice cooker and switch it on. Rice cooker cooks it automatically.
White rice does not need extra time to cook.
Brown or any colored rice should be left or soaked for 10 to 15 minutes before cooking it ( because it is a bit hard ).
Hope that helps you out.
Thanks for using FixYa!
2answers
I own a b&d hs80 steamer and don"t know how to cook rice in rice bowl? how much rice, water, time,etc to cook 3 cups?
Here is a tip that I wrote about rice cookers and the amount of rice and water needed...
http://www.fixya.com/support/r5396567-much_rice_water_go_in_cooker
heatman101
2answers
RICE COOKER WILL NOT COOK RICE
heatman101
1helpful
2answers
How do i cook rice in my rice cooker? what are th...
Just read these ratio's in "The Asian diet". 3 cups water to 1 cup rice. PERFECT!!
2helpful
How do I cook brown rice?
yup! there is a different ratio for brown rice.
1 cup brown rice = 2 cups water
hope this helps
100helpful
5answers
Rice cooker vs a crocpot/slow cooker
I have both and use both for different things. The rice cooker cooks faster than the slow cooker. What the Crockpot does really well, the rice cooker cannot do. For example, with the crock pot, you can buy less expensive cuts of meat and because of the slow cook method, they will be tender, juicy, and delicious. You can make soups, stews and casseroles in a crock pot and the great thing is that you can turn it on low, go to work, and when you come home, dinner is done. You can cook the same types of things in a rice cooker but you can't leave it all day. You CAN saute', fry, etc,. in your rice cooker which you can't do in a crock pot but for dense veggies and tougher cuts of meat, stew beef for example, there's no comparison. I have an Oster Rice Cooker and Steamer which I use nearly every day. I cook rice, obviously, casseroles, veggies, spaghetti and meatballs, all kinds of side dishes and soups in it. I use the crockpot several times a week but more often in the Fall and Winter when I make soups, stews, chilis, roasts and BBQ. Oh my gosh, you have to try BBQ Ribs in the crock pot! They melt in your mouth. Go to Yahoo! Groups. You'll find all kinds of great info for both your rice cooker and crock pot. I have one of the fancier, more expensive crock pots because I take it to work with me one day a week for lunch. The lid seals and it comes with a carrier. If you do most of your cooking at home, you can spend a little less and get a good one. I recommend getting one that has at least 3 heat settings though. Different foods require different temps. Happy Cooking!
3answers
Sticking of cooked rice inside pan
Buy a rice cooker with non-stick inner pot.
Top Aroma Kitchen Appliances - Others Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Don A
Don A
Are you an Aroma Kitchen Appliances - Other Expert? Answer questions, earn points and help others
