Kenmore 24032\24036 Top Load Washer Logo
Posted on Nov 05, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My kenmore ultra fabric care heavy duty 80 series model 110 will not drain. The problem occured after a heavy load knocked the lid switch off during the spin cycle. How do i fix this/replace the lid switch?
Anonymous
Level 3:
President:
  • Master 1,937 Answers
  • Posted on Nov 05, 2010
Anonymous
Master
Level 3:
President:
Answers
1937
Questions
0
Helped
429824
Points
5400
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Leaking washer, increases when using cold, less when using hot. May be at drain?
Stop the washer and clean up the water. Confirm that the water is not leaking when the washer is off. The leak can occur before the electric valves either where the hose connects or from the electric solenoid valves just inside the washer. The situation is more likely true if the hoses are stressed by being bent to one side.
If dry then confirm if it is the hot or cold by running the machine with the cold service valve open and hot closed.
Is there a belt on a kenmore ultra fabric care heavy duty 80 series
No. What is the problem you are having? Let me guess, it's not spinning or agitating?!
What is the model number listed under the lid?
1helpful
2answers
Kenmore 80 series washing machine will fill up with water, then nothing happens
Kenmore Ultra Fabric Care Heavy Duty 80 Series washing machine (Model # 110.92389200; Serial # CF 1122814) went through the wash cycle completely, but rinse not the rinse cycle. Motor was going but washer not spinning. Also smelled something like burnt rubber. Could the belt have gone out? Is this something that I can fix myself?
Washer won't drain
Dear cbringer,
I have the same washer. I have had the same problem with it. It's the timer module. You can get additional help from http://www.repairclinic.com.
Hope This Helps,
Jay
4helpful
How do I take apart the outer shell to my Kenmore -Series 80 washing machine?
I have Serial # CF2467934 Model # 92588210 Kenmore Ultra Fabric Care Heavy Duty 80 Series. The top agitator is stripped out, how do I take it out to replace it?
1helpful
Need cu size of my broken washing machine.
it is a 3.0 cubic foot.
  • I would do some research before spending a lot of money on a front loader.
Alexander
vince
