SOURCE: sANYO EM-D9550. Turntable turns when off but not when cooking.
That's sounds pretty strange!
Since I don't have any service data on Sanyos, I'd have to speculate.
I would guess that one scenario that could cause it would be if the turntable were turned off via the control panel, but there was a switch or switch mount problem.
I would refer you to their support people:
http://sanyoservice.com/
SOURCE: microwave not cooking
I would say you have a bad door switch or door switch mount, or your door is loose or out of alignment.
But since it's new, and under warranty, I would contact Goldstar (LG) customer service to have them repair it free.
Contact LG at 1-800-243-0000 or http://us.lgservice.com
We're happy to help and we appreciate your thoughtful rating of our answer.
SOURCE: Lights, fan,etc work but turntable does not rotate and oven does not cook.
Sounds like the table motor may have an issue. You might want to consult you local repair depot for an estimate. Sometimes the repairs are more than the appliance...beware!
SOURCE: Microwave light bulb out
This is simple, and "FixYa" technical staff has clearly not looked at our model.
Take off the vent across the top (three long screws) to expose a single screw over the keypad.
Remove the single screw, and the whole keypad consile will lift up and off, likely hanging by a plastic tab/support on the bottom.
Now you can twist the light bulb plug to remove it from the support structure, change the bulb, and replace all that you've done.
Simple.
SOURCE: Microwave just stopped cooking!
The simplies is the fuse, which is located inside the unit, you need a screwdriver to open it
