programmmming TVTV control The Comcast DTA remote control is preprogrammed at the factory to operate the DTA receiver. The Comcast DTA remote also contains a universal TV library to allow you to control the Power and Volume of your TV. 1. Turn on the TV NOTE: Please read steps 2 to 4 completely before proceeding. Highlight or write down the codes and device you wish to program before moving on to step 2. 2. Press and hold Setup until the Red Light blinks twice, then release Setup. 3. Locate the code for your device in Manufacturer's Codes on the back of this user guide. Brands are listed in alphabetical order with the most popular codes listed first. 4. Enter the first five-digit code for your TV. If you perform this procedure correctly, the Red Light will blink twice NOTE: If you enter an invalid code, the red light will display one long blink and exit the programming mode. Repeat steps 2 to 5 with a valid code. 5. Aim the remote control at your TV and press Power once. The device should turn off. If it does not respond, repeat steps 2 to 4, trying each code listed for your brand until you find one that works. If it still does not work, try Searching For Your Code.
Most universal remotes have an automatic code search. If you google your universal remote, you should be able to find instructions, including how to do the auto-search. If you still have problems, just let me know. I'll do a little more research for you.
Der Strom
I have a Trutech 10 inch under cabinet DVD/TV and needed the codes for the new Digital Adapter that Comcast is forcing everyone to move to. The short answer is that there isn't a single code that will work for what we all need. After much research I have an answer. It's largely unsatisfactory, but its somewhat of a work around. If you use code 10451 you can get the channel up, channel down, the number pad and the "last" button to work. To get volume functional, change the volume lock on the comcast box. To do this:
1. With the TV on, manually set the volume to a medium high setting
2. With the comcast remote, press and hold SET until the red light blinks twice.
3. Enter 9-9-3 (red light blinks twice)
4. Press and release the digit 1 (red light will blink 4 times)
Now, in addition to channel control, you have volume control. I can't do anything about the power button or other functions. However, this at least makes the remote functional.
