Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140 Logo
Posted on Nov 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to diagnose makita 18v impact losing power. Already replaced battery
Repair Ahjoshe
Level 3:
  • Makita Master 885 Answers
  • Posted on Nov 04, 2010
Repair Ahjoshe
Makita Master
Level 3:
Answers
885
Questions
0
Helped
642313
Points
2112
If the battery didn't take care of the problem check the brushes next. Take the two screws out of the back cover and check both brushes (Part Number 194427-5). They should be at least 1/4" long and evenly worn, if not replace them. If they're excessively burnt or chipped and broken, check the armature before replacing them. If the commutator is damaged it will only shorten the life of the new brushes.
Makita instructions
It slides onto the top of the battery pack.
Can you fix a lithium battery?
The Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140 us the BL1830 battery, there are several types for it, 1.5Ah, 3.0Ah, 4.0 Ah. Maybe 5.0Ah battery for it will be available. And, the inside of the BL1830 uses the 18650 battery cell. If you have a good knowledge and skill about electronic, you can buy some 18650 cell to do it yourself. If not, I suggest you to buy a brand new one.
You can buy some original battery for replacement battery for Makita BTD140 Battery
2answers
Why will a makita Li-ion 1.3ah battery not fit in other makita tools?
Some of the Makita 18v LXT tools require the BL1830 3.0AH battery and are designed that the 1.5AH battery will not fit.
1helpful
My makita impact driver has lost power. it seems to be using the hammer much more and seems to be slipping. both the hammer and the andvil don't appear worn. the bushes are fine. what could be the problem?
This is more then likely caused by the plastic gears inside the drill wearing down. Makita may replace/repair under warranty depending on when you purchased the drill.
1helpful
3answers
Makita 1420 - 14.4v 1.3Ah cordless drill
try toolpartsdirect.com & go to makita & type in model #
Top Makita Drills Experts
Sean Wright
Sean Wright
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Makita Drill Expert? Answer questions, earn points and help others
