SOURCE: Boost Volume On 5th Gen 8G Nano
You want to select volume booster in the preferences tab in itunes and it will boost the volume on all songs.
SOURCE: charging ipod nanon 4th gen on bose sound-dock
http://www.scosche.com/products/productID/1694
Click on the link above for the solution for your problem
SOURCE: How to turn off speaker when using headphones
Just had the same issue with my GF's nano so i phoned apple and got the following solution:
Flick the button/switch on the top of the nano on and off 6 times leaving the orange bit not showing.
Now hold down the menu button and the middle button for 15 seconds until an apple icon appears. SORTED!
now the speaker turns off when you plug the headphones in plus rest assured it doesn't reset the ipod and remove your songs.
SOURCE: .how to unlock a ipod nano 5th gen. without the
According to Apple, if you have forgotten the code, you can unlock the IPod by doing the following:
Connect your IPod to the primary computer you use it with (the first one IPod synced with), and open iTunes.
When you disconnect iPod from the computer, it will no longer be locked.
If you can't unlock IPod using either [the code or connecting it to the computer you use to manage its songs]. . . you can restore your iPod to factory settings using iPod Updater. Please note that this will erase all data on your iPod.
Afterwards, you can add your music and data back to your iPod.
If you want to change the primary computer that your IPod is associated with, do this:
1. Restore your iPod. WARNING: The restore process cannot be undone.
All of your songs and files will be deleted. Always make a backup of your important data.
2. Connect your iPod to the computer that you want to be the primary computer.
3. Open iTunes and synchronize.
Apple also notes that company "representatives cannot unlock an iPod if you forget your combination. If you can't unlock your iPod and you don't have access to the primary computer, your only option is to restore the IPod, which will erase all music and data."
For this FREE answer, Please rate me
