Cars & Trucks Logo
Posted on Nov 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What is the Recommended oil weight for 1987 2.8 v6 fiero
Harvey N Tawatao
Level 3:
  • Pontiac Master 3,854 Answers
  • Posted on Nov 04, 2010
Harvey N Tawatao
Pontiac Master
Level 3:
Answers
3854
Questions
0
Helped
2796352
Points
16501
1987 PONTIAC FIERO 2.8L 6-cyl Engine Code [9]
All TEMPS......5W-30 SAE 5W-30 is preferred.
CAPACITIES: Engine, without filter..........3.8 liters, Add extra oil when replacing filter. After
refill check oil level.
Oil Drain Plug.....15-20 ft/lbs
Thank you for using fixya and good luck
Marvin
Level 3:
Top Expert:
  • Pontiac Master 85,242 Answers
Marvin
Pontiac Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29053559
Points
266281
Since 1980, the preferred energy saving viscosities for GM gasoline engines are SAE 10W-30 for the larger engines and SAE 5W-30 for the smaller engine, so the recommended oil is 5W-30W for the V6, if the engine is high miles u can run 10W-30W if you live in a warmer climate.
Where do I hook up a tow rope on rear of fiero gt 1987 I just need to pull it back about 6 or 7 ft.
Search Results
    Pontiac Fiero Tow Hooks at Andy's Auto Sport
    www.andysautosport.com > ... > Pontiac Tow Hooks > Fiero Parts
    At Andy's Auto Sport, you can find Pontiac Fiero Tow Hooks at a great price. ... a ditch most tow truck drivers will hook up to a suspension piece or bumper risking ... Bolting a set of Pontiac Fiero tow hooks to the front and rear of your vehicle will ... Tow hooks provide a convenient and secure place to attach a tow rope or tow ...
    How to tow a Fiero with a pickup truck? - Pennock's Fiero Forum
    www.fiero.nl/forum/Archives/Archive.../20110502-2-106918.html
    Mar 3, 2010 - 40 posts - ‎9 authors
    OK, I have to go pick up a Fiero from Miami this weekend with my ... a strong rope. and someone inside the fiero pushing the brake pedal :P ... Went a tow dolley and towit by its back wheels and brace the ... any good tow points under the car, unless youhook it up to an a arm, .... 1987 Pontiac Fiero SE / V6 Hookup for raising car for engine cradle removal
    Feb 6, 2009
    U-Haul says "no" to using a tow dolly?!!
    Oct 31, 2008
    More results from www.fiero.nl
    What to do when your car has no tow hook - NWautos
    blog.nwautos.com/.../what_to_do_when_your_car_has_no_tow_hook.ht...
    Mar 13, 2011 - I know most SUVs have a hook on the front or a hitch on the back, but I cannot seem to find anything ... Where can I safely hook up a tow rope?Missing: fiero ‎1987
What are the oil pan torque specs on a 1987 Pontiac Fiero GT
To install: Place a 3mm bead of RTV sealant on the oil pan sealing flange.
Install the oil pan and torque the 1 inch bolts to 6-9 ft. lbs. (8-12 Nm) and the 1.5 inch bolts to 14-22 ft. lbs. (19-29 Nm).
Install the starter assembly.
Install the flywheel and clutch housing cover.
Lower the vehicle and refill the crankcase with the specified engine oil.
Start the engine and check for oil leaks.
The battery and oil pressure gauge pegs - 1987 Fiero GT
check for a pinched wire that goes to the gauges.. its grounding out.
1helpful
I need a firing order diagram for a 1987 pontiac fiero
1987 Pontiac Fiero
2.5 liter L492717859.gif 1987 Pontiac Fiero
2.8 liter V-641894283.gifPlease rate this help.....Notice there is v6 and 4 cyl makesure you get the write one
I need to locate the OBD socket on a 4 culinder 1987 Fiero
I own multiple fieros, it is behind the power point behind the shifter, remove the 2 screws and it is there, it isnt very convenient?
I have a 1987 pointiac Fiero. It has the 2.5L 4
It gives 3 quarts just as a starting point, it says this for the 4-cyl and 6-cyl, just so you don't overfill it. The distance between the two marks/notches on the dipstick represents 1-quart. If it's exactly on the low mark, then add 3/4 of a quart and see where it ends up, should be about 3/4 of the way to the other notch. Don't add quarts at a time, overfilling your oil can be just as bad or worse than if you underfill it. You'll be breaking oil seals all over....not good! :)
have fun
2helpful
2answers
if you've added the oil and started the car and the oil level is at the add mark with the engine off, allowing a minute or so for the oil to drain back down to the oil pan, add 1 more quart
1helpful
2answers
Change oil & filter - Dodge Ram b150 van
you will need at least 5 or 6 qts. you can decide on the oil filter and the kind of oil to buy, they have valvoline, pennzoil, exxon, all kinds and the oil filter, they sell purolator, ac, fram,(fram is what i buy). if its got high miles, then use high milage oil.
Top Pontiac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Pontiac Expert? Answer questions, earn points and help others
