The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key.
The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings.
To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
To add a PC (Not laptop) it must have a wirless USB for it.
Using that PC search for wirless networks.
When it finds your one click on "connect to it" and a box should come up requesting the WEP password, simply type in this password and Ok it, job done.
If you have forgotton password you will have to reset the router and set it all up again :( with new P/W
You can secure your wireless network wit WEP or WAP code. For that Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.0.1 or http://192.168.1.1 For belkin router http://192.168.15.1 or http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Click
on wireless settings then enable WEP Security then add WEP code .It is
your password to connect wi fi.Then save settings and restart router. Then you can connect your wi fi network with that code. Thanks for using FixYa.
if you want to go wired on your router, you dont need a password.
If you want to connect wireless and forgot the wireless password, then
1. Log on to the web interface of the router and change the password in the wireless settings.
2. If you have more time in your hands , reset your router and bring it back to factory defaults and set it up all over again
Thanks Ranjit
Are you trying to connect to the wireless network ? Or your new computer will be connected to router with the cable. If it is hard wired to the router and the router is working for the other computers then you don't need to change anything on the router. If you are trying to connect to the wireless network then you should know the wireless settings of the router. Click Here for step by step solutions
go to 192.168.2.1 >wireless security page. There you will see your old key. Erase it and type in your new key. It is going to ask you for the password if you have set one. If you have not set one, leave it blank and press submit. If I could be of further assistance, let me know. If this solves your issue, please be kind to rate it. Thanks, Joe
Go to Start>control panel> Network and internet> network connections > right click on wireless network > select 'view available wireless networks' and select your home network and click connect. If it asks for a password i guess u have it or if u dont have then go to Internet Explorerand and type 192.168.1.1 in the address bar, it will ask for a username and a password, type admin as username and the same for password. it will take you to the lynksys page....then select wireless and click wireless security, it will show you the wireless password.......
If u have windows vista :
Click Start > go to 'connect to' > select the wireless network you want to connect to and the rest is the same as windows xp....
