Question about Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White
Whirlpool Self Cleaning Oven - Model RF360BXXW Serial # FA4005915 Turned oven on bake - bottom element is not heating however top element is. Tried to change setting to 'timed bake', 'broil' and 'clean' - only top element turns on. Please help - I've got lots of cakes to bake! Thanks
  • 244 Answers
Your lower element may be burned out. Generally you can firmly grasp and pull it out. Take it to a repair shop and get a replacement unit. Then simply snap it back into the same outlet where you remove the first one. It sound as if you've tried everything else so it must be the unit that is bad.
Posted on Nov 04, 2010
6ya staff
SOURCE:
Both Oven elements do never come on Together, Top Works When turn on Broil and Bottom when On Bake & Auto. Pls help.
that's normal. The top element is meant for broiling only while the bottom one is meant for baking.
Mar 11, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
The bake element (in over) will no longer get hot, should the element itself be replace or could it be something else? Range model RS675PXEQ0
It does sound like the bake element is probably the problem. Many ovens turn on the broil element with 120 volts to even out the heat in the oven or pulse the broil element. This may be why the oven is warm but not baking.
Nov 12, 2013 | Whirlpool 30" Self-Cleaning Freestanding...
Whirlpool built in electric oven bake (bottom)heating element does not heat up only tot heats when in bake mode
CHECK FOR CRACKS IN THE BAKE ELEMENT. IF THE UNIT IS NOT HEATING THE BOTTOM, BUT THE TOP IS STILL HEATING, YOU MORE THAN LIKELY HAVE TO REPLACE THE ELEMENT. THIS IS A 220 VOLT OVEN WITH 110 VOLTS ALWAYS GOING TO THIS ELEMENT, SO TURNING OF THE BREAKER IS VITAL FOR SAFETY PURPOSES. WITH AN OHM METER, UNINSTALL THE ELEMENT AND CHECK BOTH WIRE CONNECTIONS FOR OHMS. YOU SHOULD GET SOME KIND OF READING BETWEEN 10 OHMS AND 500 OHMS. IF YOU'RE NOT AT LEAST GETTING A SOLID READING, REPLACE THIS ELEMENT.
Jan 24, 2013 | Whirlpool 24" Double Electric Built-In...
Baking on two racks - whenever I try to bake cookies on top and bottom racks, the lower tray does not bake anywhere NEAR as quickly....should I be able to bake evenly on up and down racks?
Two racks never bake as evenly as one unless you use the fan inside the oven if you have one...The fan will also shorten the baking times...
The other thing that I would check is to make sure that the lower element in your oven is not blown and you are heating with the top element only...
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Oct 02, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
After putting my 10 yr. old Whirlpool Model RBD276PD double ovens thru the self cleaning cycle the bake and broiler elements in the bottom unit stopped heating. All the controls on the panel work and the...
This sounds like it blew the thermostat on the back of the lower oven. They are inexpensive and easy to replace. You will need to uninstall the unit and remove the back panel to acess. Check it for continuity if none replace. This is a fairly common failure due to the heat of the self cleaning. Here is a link to your part and diagrams are also available there AP3055316
Sep 28, 2010 | Ovens
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Circuitry may have gotten tripped during clean cycle. Oven will open and electronics work but neither element will heat.
baked control module for heating elements. if you have a volt meter, check for power when oven on, if no juice its the control element, if you do get juice then its the elements
May 28, 2009 | Whirlpool GBS277PRS Stainless Steel...
Whirlpool oven issue
Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Oct 26, 2007 | Whirlpool RBS305PDS Electric Single Oven
Whirlpool 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
217 people viewed this question
Top Whirlpool Ovens Experts
John Tripp
John Tripp
Marvin
Marvin
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
