The top oven in convection mode works fine however in bake mode it will only get up to about 510F of a possible max of 550F. The clean mode also will not get hot enough to clean. Could it be the door seal which looks a bit brown and is quite hard? Could it be that there is a separate thermostat for bake mode that is failing? The oven is about 8 years old. Any ideas?
I will say that is the control board that is not working properly. Have you try to unplugged for phew minutes?, this will reset the current settings. If not, I will star replacing the control board. Good Luck!.
it could be the oven temp sensor rod located near the top of the inside of the oven,or possibly the bake element has a hot spot on the element and can no longer pass enough current thru this spot to correctly heat to your settings a hot spot on the element will look discolored in this area
When I turn on my Maytag performa using the "bake" function, everything looks ok on the display, however the temp. never rises above 100. I've tried "bake" and "convect", and neither one work. "Clean" doesn't work either. The oven will lock, and display shows that it's heating up, but temp. never rises. However....."broil" feature works just fine. Please help.
If not, then it should not be a Concern. More often this could be Thermal Fuse on the Back of the Unit ( On Most Models ) will stop the Broil and Bake from Turning ON. You would just start a bake cycle and the temperature will sit at 100 and something degrees and never raise.appliance.
The Taylor oven thermometer you bought is decent at best. It is most likely the sensor inside the oven. Has your clock displayed any fault codes? F, followed by a number? Changing the sensor will probably correct the problem.
possible that the insulation that surrounds your oven cavity has yet to fully cure, i would run a clean mode, this will get the unit to max temp fro 3 hours, fully curing any insulaton for sure
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
