Panasonic Panafax UF-585 Plain Paper Laser Fax Logo
Posted on Jun 13, 2008
GETTING COM AS 634 INSTEAD OF OK STATUS WHAT IS THE REASON
A
Anonymous
This is what the code means:
Redial was not successful due to no response from the called station or wrong number dialed.
Note
: If busy tone was not detected, the machine will only redial once.
So the your fax machine is getting no response from the fax you're calling.
Hope that helps...
I have a 07' MK5 GTI and i need help figureing out why im getting absolutly no boost. ive used the vagcom reader and it threw some codes that i have no freaking clue about please help me.
so,you have Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 04-Steering Angle , Status: Malfunction 0010 0F-Digital Radio -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 46-Central Conv. -- Status: Malfunction ,start by repairing these codes to figure out your boost problem
Trouble code p2454
To Hi
I got this problem in Skoda Diesel Particle Filter, I have check the wiring all is perfect , then I have change it but the same problem .
will anybody tell me how can I solve this problem please ,
PS. after deleting the fault it came back
Regards
______________________________
Saturday,06,July,2013,17:18:03:25282
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.10.6.2
Data version: 20130531
Dealer/Shop Name: EEPROMKFZEEPROM WORKSHOP .
Workshop Code: 123 12345 023456
VIN: TMBHT61Z5A2101325 License Plate: PROBLEM
Chassis Type: 1K0
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 69 72 77
01-Engine -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 1010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Sporadic communication error 1000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 AG HW: 03L 906 023 AG
Component: 1,6l R4 CR td H23 5697
Revision: -------- Serial number:
Coding: 00114016032400080000
Shop #: WSC 73430 031 00999
ASAM Dataset: EV_ECM16TDI02103L906023AG 001003
ROD: EV_ECM16TDI02103L906023A.rod
VCID: 6BDFA3EE82E73246487
1 Fault Found:
7397 - Diesel Particle Filter; Differential Pressure Sensor
P2454 00 [175] - Short to GND
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 166872 km
Date: 2038.14.06
Time: 00:13:34
Readiness: 0000 0000
End ----------------------------------------------------------
Need user manual for mylock 634
You can view and download the instruction manual in PDF format by clicking this link.
For further details and videos, click here
You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Thanks for using FixYa.
1helpful
Cannot log on to Contribute CS4, given no. 148:3 as reason
Hi
it seems that you are getting this error because of
"Licensing for this product has stopped working"
check the following steps
  1. Choose Start > Control Panel.
  2. Double-click Administrative Tools.
  3. Double-click Services.
  4. Double-click the FLEXnet Licensing Service to open the Properties dialog box.
  5. Click the Startup Type menu, and then select Manual.
  6. Click Apply.
  7. In the Services Status section, click Start to start the service.
  8. Click Apply, and then click OK.
  9. Close all open dialogs.
  10. Launch your Adobe application.
else download the Licensing Service Update.
from the following link
http://www.adobe.com/support/contact/licensing_download_eula.html
1helpful
Ej # 1 slot getting cd error not loading or playing
Try a new cartridge, they do warp over time. That would be "best case scenerio" worst case is the optic is shot/out of alignment, etc. There should be a reset button on the changer below the cartridge "(@)" small pen sized dimple that can be pushed w/a ball point pen to reset. How old is the unit? it's still in the current lineup. If it still doesn't work, call Alpine USA, give them the serial # if you don't have a receipt for it. They can tell you when it was manufactured to check for warranty status. Otherwise your looking at $100 - $150 repair. They would just swap out the transport. Best of luck!. Hope this helps!
Getting weird comm.
error code 634 means that your machine tried a phone number and reached its redial limit. does this happen to every call or just one number.
if its all the time it could be you phone line is not connected or you need to do an all job clear
Canon MF6550
Try to press te System Monitor Button and scroll using the > to Print Status. If there is a print job in there press ok the < to cancel the print job. You may want to check the other status windows in case it is a Fax or Copy job instead of a print job.
2helpful
Elna 634 manual
Here is ELNA in USA, they offer a dealer locator to find one nearest you, or just contact them direct with your request.
http://www.elnausa.com/
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
