Sir, my tv's interface has changed a lot. wen d tv is switched on it shows 'videocon' instead of 'sansui'. the main problem is i cannot tune d various channels. various important options like auto search have been disabled. it is impossible to tune d channels wid out dese options. wen d menu is accessed, d disabled options show a lock symbol near it. PL PL HELP ME
replace eprom IC and set brand name by using videocon service remote.u can also desable tuning lock by pressreplace eprom IC and set brand name by using videocon service remote.u can also desable tuning lock by press
You can't post conmments that contain an email address.
Today videocon, akai and sansui are doing on a same platform. You need to go into the service menu, and change the remote options. If you wont be able to do this, then i suggest you to get a universal akai, videocon, sansui common remote handset and it ll work
What is the exact model number to your Videocon TV? Videocon uses both Toshiba and Sansui kits. Without knowing the exact kit fitted, it is difficult to inform you the correct service mode option. Anyway, check this and see whether it help you.
Hello
Universal remote codes for Sansui TV with RCA RCR311B remote control are:
1020, 1054, 1133, 1145, 1167, 1230
But I really don't understand to what do you mean by this ASM lock. ASM [Automatic Search Memory] is meant for tuning fuction. When we put the set to ASM mode, it should search all the available programmes at that time at appropriate chanels, and will stop; must stop; at the end of the tuning is over, and must show the first received programme. Then we can change the programmes as our own select. If ASM function does not works with your TV as specified above, surely its memory IC is in trouble; damaged; and should replace it with same type and number. This IC is an eight terminal one, can be located very near to main system control IC of your set. OK.
Usually, once child lock is on, the set will not respond to the front panel buttons and you need the power button on the remote control to turn the TV on. Then go into the menu and turn child lock off.
