You will need to first review the RAM requirements (ie: maximum) etc and how many bays / how many sticks of RAM.
Hey there,
I have set up my new office and planning to buy some network switches and routers. A friend of mine has advised me about Bitsync Digital. Can anyone please give me some review about it? https://bitsyncdigital.co.uk/networking-devices/switches/network-switches
Thanks
WARNING: When updating memory cards, they must be installed in PAIRS! You can not have 2 different size cards installed! My advice, try removing the smaller card and try it with just the larger one in the first slot! That should solve the problem! Better late then never? : )
Hi this model sopport 2Gig Memory Ram.
RAM Technology
DDR SDRAM
Installed RAM
512 MB
Max Supported RAM
2 GB
Number of Memory Slots
2 x DIMMs
Supported RAM Speeds
400 MHz • 333 MHz
Installed Cache Memory
256 KB
RAM Technology
DDR SDRAM
Installed RAM
512 MB
Max Supported RAM
2 GB
2 x DIMMs
400 MHz • 333 MHz
256 KB
RAM Technology
DDR SDRAM
Installed RAM
512 MB
Max Supported RAM
2 GB
2 x DIMMs
400 MHz • 333 MHz
256 KB
RAM Technology DDR SDRAM
Installed RAM 512 MB
Max Supported RAM 2 GB
Number of Memory Slots 2 x DIMMs
Supported RAM Speeds 400 MHz • 333 MHz
Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
As for the choice of memory, look at yourself herehttps://gadgets-reviews.com/review/889-b... A cool site and there is a great choice, so you can familiarize yourself
Dell Dimension B110 PC Desktop circa 2006(spec is at dell.com if you can read RTM)
15year old PC,
no statement at all what all ram used, there are 2 slots, what did you put on BOTH slots not told
if one slot only used, Bank0 channel A, must be used only. dell and intel both told you that..
no pc on earth runs with a 15 year old RTC coin cell battery , NONE. and is first first on all PCs
oK is that clear.?
1: did not reset BIOS
2: wrong ram (new RAM in old PC love to fail for DDR density (DRAM) too high now)
3: did so with power cord AC to wall jack BOOM now wrecked it.
I am reading your manual to you now. page 11.
2 slots. OLD DDR1 MEMORY (relic ram not ddr2,3, or 4 is relic)
DDR333 and DDR400 memory runs at 266MHz when configured with Celeron 400MHz FSB processors NOTE: DDR333 memory runs at 320MHzwhen configured with Pentium 4 800MHzFSB processors
the above 2 lines means use faster RAM of the FASTER CPU option not told by you or just use 400
128-, 256-, 512-, or 1-GB non-ECC (options day 1, new, 15years ago)
min. size 128MB never smaller per stick
2 GB max for system that means 1GB x2 max per PC.
PC is usless for windows 10, did you know that before spending cash first? ask first then leap, why not?
do not mix rams sizes in 1 PC. (1 bank)
do not mix SKU, that means matched RAM in each channel pair A/B. , INTEL.com rules.!!!
the BIOS must see the RAM. first.. (after new RTC CMOS coin battery put in)
again if using only 1 stick of ram , it must go in to slot marked channel A (of 2 slots0
then in BIOS click reset defaults.
then in BIOS Turn off PXE in BIOS NIC page
then set boot order to HDD first and do not allow PXE to be here ever.
see PC boots if HDD 0 is good, and none are 15 years old.
page 12 intel data sheet. clear facts.
old 15 year old Intel® Pentium® 4 with HT Technologyand Intel Celeron Intel 865 GV
the 845GV must be made happy first.
the 845 runs RAM, not the CPU back thin 15years ago.
845 allows 4 DDR slots, but Dell used 2.
845 allows, max 4GB of ram but that is 4 slots so is really 2GB via DELL limit
845 allows, (MMC) single channel mode, that is correct just 1 stick of FRAM
how ever the 845 was only only tested up to 512MB sticks no 1GB then. so could not be tested.
that means YOU GET TO FIND OUT. the HARD way.
again only 512MB max sticks o RAM were tested the and this rule (intel MMC logic rule)
e.g., double-sided x16 DDR SDRAM DIMMs) are not supported.
this post is for hyjackers or w10 failures.
Anonymous Apr 23, 2020
your link site stinks (and does not focus only on DDR at all)
it does not cover density or rank rules on DDR1 at all and is what matters most, year 2006 with 2004 (845chiP)
as do sku rules, mixed DDR rules and double-sided x16 DDR SDRAM DIMMs limits
and more, you DDR page is useless.
the best answer is buy only CERTIFIED DDR1, ram, but most makers ended support long ago.
