When you use the Colors window to select colors for text or objects in a document, you can also assign a color profile to the document. Color profiles help ensure that the colors you see in the document onscreen match the colors in the document when it's printed or viewed on another computer.
To choose a color profile for a document:
In your document, select the text or object whose color you want to change.
Open the Colors window.
In some applications, you can open the Colors window by choosing Format > Font > Show Colors or Format > Show Colors. In some applications, you can also click a button in the application's toolbar or a settings pane.
Click the Color Sliders button.
Choose a slider option from the pop-up menu.
Drag the sliders or enter specific values to adjust the color.
Click the colored box next to the pop-up menu and choose a profile from the list.
If you open your document and the colors appear in a different shade or hue than you expected, the application you're using might not recognize color profiles. Try using the generic color profiles instead.
In some cases, an application may not open documents that use non-generic color profiles.
You can create your own custom color profiles using ColorSync Utility. For more information, open ColorSync Utility and choose Help > ColorSync Utility Help.
having same color issues from what I see on the monitor to what is printing on the Epson 1400. How do you calibrate your monitor?
