Kenwood KDW243A Builtin Dishwasher Logo
Posted on Nov 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Kenwood dishwasher keeps displaying error message E4 but there is no mention of this in the user manual. Can you explain what this means
Oloyede Monsuru
Level 3:
  • Master 1,468 Answers
  • Posted on Nov 02, 2010
Oloyede Monsuru
Master
Level 3:
Answers
1468
Questions
0
Helped
407727
Points
4011
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
Hope this help?
Thanks.
1helpful
3answers
How to fix error e4 code on kenwood dishwasher
This is the flood code. Shut the power off at the main and remove all the water from the inside manually and then reset and try it.
Kenwood KDW12ST3A dishwasher keeps bleeping and showing E4
Many owners manual list common error codes. I would check there first. If that doesn't work try repairclinic.com and access trouble shooting DIY help by model number for model specific information. Good luck.
1helpful
I have e4 showing
E4 error indicate an abnormal water level which means too much inlet water (E5 also is refer at this fault).
I quote other comments/solution about this same error:
I had the e4 error code and i took the outer panel off and inside behind the power button is a grey reservoir tank which measures the water that goes inside the dishwasher which actually got bunged up with **** and grease causing the floaty thing to get jammed and cause the e4 code to come on which means abnormal water level the top to the reservoir just unclips on both sides then just clean all the gooey stuff out and put it back together it worked for me.
Good luck.
2helpful
4answers
My dishwasher says E4
The error code E4 means selector switch pads is stuck.
First try a hard reset. Unplug the unit for 10 minutes and then switch on the dishwasher. Most cases you won't get the error message.
If you still get the error message then you need to take to service center to get it repaired. Mostly, the inner connectivity between the pad and circuit board is loose/bad.
Hope this helps.
Shane
Disherwash is showing e4 what does it mean
The E4 error is not usually associated with newer dishwashers. Older Kenmore dishwashers with digital displays would show an E4 error when the selector switch pads/buttons were stuck. You need someone In to look at it im afraid
My Kenwood Dishwasher shows an E4 error code
Howdy:) An E4 or E5 error indicate an abnormal water level which means too much inlet water. Here is the shortcut to the Kenwood PDF file with the user's manuals.
http://dl.owneriq.net/4/4e71b4c9-e100-4066-a29e-9c46abc1f5cf.pdf
You can cut and paste it into your browser's address window. Your model was not indicated in your message, but the error codes are standard throughout the Kenwood models. I hope you find this useful:)
1helpful
Kenwood kdw243a
The dishwasher still has water in it.  Lean dishwasher back at least 45 degrees and water should drain out through overflow pipe.  It could be caused by the dishwasher not being level.  Otherwise from reading reviews online it seems to be a common fault with this dishwasher and lots of people have returned and purchased different.
Sep 28, 2008 • Dishwashers
35helpful
4answers
Kenwood dishwasher KDW12SL3A
Sounds as though the drain is blocked partially. E4 is the overfill code. Try cleaning out the drain.
Aug 07, 2008 • Dishwashers
15helpful
2answers
I HAVE A KENWOOD KDW12ST3A DISHWASHER AND IT HAS THE E4 ERROR CODE THEY DID NOT GIVE ME A MANUAL WITH IT CAN YOU HELP
i hav a kenwood kdw12st3a and the e4 code came up and it said in the manual it had overfilled but it did'nt tell you how too fix it can you help
Top Kenwood Dishwashers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Kenwood Dishwasher Expert? Answer questions, earn points and help others
