I bought a 26 inch Daenyx LCDHD TV ftrom Walmart. A few months later the remote quit working and Walmart would not help.
Where can I get a replacement remote control or the code?
Thanks, MershaI bought a 26 inch Daenyx LCDHD TV ftrom Walmart. A few months later the remote quit working and Walmart would not help.
Thanks, Mersha
You can't post conmments that contain an email address.
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Unlock procedure and to override the password lock of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts.
0658 0673 0680 0697
Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience. http://electro-medical.blogspot.com/ http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls.Common codes to check devices with different brand TVs are given, in the order of the device's brand name list in alphabetical order.Pull up older posts. Surf the site with patience. http://remotesearch.blogspot.com/ http://electrohelponline.blogspot.com/
couldnt find the type of tv you have but i found something that might help you can try these
0005, 0017, 0047, 0050, 0062, 0103, 0146, 0156, 0486, 0237 or you can try doing a code search with the remote below is how to do it
Manually turn on the device (TV, VCR, etc.) to be controlled. 2. Press and hold the CODE SEARCH button until the red indicator stays on, then release the CODE SEARCH button. 3. Press and quickly release the desired mode button (TV, VCR, etc.). The red indicator blinks off once. 4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press. If you accidentally overshoot the code required, press the CHANNEL DOWN button to backtrack through the library until the device changes channel. Pressing CHANNEL UP changes direction to forward again. 5. Press and release MUTE to install the code.
My Daenyx DN-191 D TV remote stopped worked after a while. I didnt get one universal remote that works with this piece of junk. I called their customer service at 1-877-329-8351. They said the remote will be $30 + $7 (shipping) + tax. Your best bet will be to buy a replacement remote or better toss this junk off the window.
Thanks, Mersha
