Went to back up and somewhere in the process it stops and says there is a corrupted file on the external drive and to use a disk error checking tool. Where is that? thanks!
System file corruption. I remember it happened to me some years ago. You'll need a way to boot that is not your corrupted disk like a repair disk or a bootable USB. always make/keep a repair disk for times like these.
Here's info on how to fix it once you've found a way to boot with the same windows version as you have on your laptop:
try going to the bios and change the boot sequence for hard drive to cd
put the copy of xp in the external hard drive and reboot the computer
when it powers up it should boot up off the external hard drive
if that works go to computer --device manager and find recovery section
you may also go restore to a previous date and try for a fix from there
go google and get to microsoft and find that file download for xp and install it
if all that works shut the computer down and reboot back to bios and change back to reboot from hard drive
remove the disc from the external hard drive
you could run the check disk utility click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive or go to control panel administrive tools computer management you can right click on the drive select properties tools check now?tick in both boxes to scan for and repair/recover any bad sectors and automaticall fix any corrupt files in xp hope this helps
You most likely need to delete the partition on your external hard drive, then create a new one and format it again. You will lose the data on your external hard drive.
1. Go to the Control Panel, click on Administrative Tools, click on Computer Management, then Disk Management. (You will need Administrators rights to carry out the following tasks)
2. On the lower Right Panel select the External drive, this will be displayed as Disk 1, Right click on this drive (MAKE SURE YOU DON"T SELECT THE C: DRIVE which will be displayed as Disk 0)
and then Delete the partition.
3. This drive should then be Unallocated, Right Click on this drive and create a New Partition.
4. Then select Primary partition.
5. Check that the maxium disk size matches close to 240000(MB) you about 10+MB in the formating process
6. Click Assign the following drive letter (let the computer select this.
7. Chick Format the partition with the following settings
File System = NTFS
Allocatin unir size = Default
Volume label = "name of your choice eg. BACHUP DATA"
DON'T TICK Perform a quick format & Enable file & folder compression
8. Click Finish
Hi and thanks for writing back. I found that since the drive turned to a raw that windows will not read it.I don't know why it turned from ntfs to raw but it did. so I downloaded the O&O file recovery trial ver.to see if I could recover the pics. and movies.It took 5 hrs. to run and it recoverd everything.now I have to buy the software. but I know it is still all there.this software will even recover reformatted drives.Anybody that gets the same error mess. look to see if your file system has changed.If so it looks like recovery software is the only way to go.I have other good info on this and other maxtor hdd I will check back on post and write if you have sim.probs.
Well i guess that either your file system is corrupt or your disk is formatted into a filesystem that it's not supported by the backup programs. I don't really know what filesystem is your disk formatted into but usually the FAT32 and FAT16 are the most failsafe file systems for Windows. So copy/paste the data you don't want to loose and then go to My computer -> right click on the drive icon -> format and then choose fat 32. Then try backing up your laptop again.
