To master reset your phone Z550i, go to Settings> General > Master reset > Select Reset settings to delete your changes to settings or Reset all to delete your changes to settings, all contacts, messages, personal data, and content you have downloaded, received or edited. Then press continue. Hope this helps!
Hi ,
To format ur mobile , Do the following steps
Select Menu >Settings >General>master reset then select continue
NOTE : Take a back up of ur contacts and other important data . All the files that u have stored in ur phone memory will be formated .
For any quires write back to me .If yo are satisfied with my answer please vote for me(with atleast 3ups) . thanks in advance
Don't worry there is Solution to Unlock the Mobile Phone from the Security Lock....Use the Master Reset Code and Unlock the Mobile....I unlocked my mobile Nokia 6600 using the Master reset Code,I got the Master Reset Code herehttp://www.superunlockcodes.com/unlocking-services/rs12wp6/ and Unlock it........You Check Master Reset Code for Your mobile in the List
In the settings, you'll find something called Master Reset. This will erase all data whatsoever on your phone and reset it to its factory state. Try and tell me if it doesnt work
there is two options1. Trun off your mobile and remove your battry again turn if on this may fix it. 2. The other option is more possible to solve it you have to make master reset your mobile it is 100% chances after this your wlakman will start working. Remember to safe your all contects and messages all other thing before master reset. Hope this will help you.
Connect the phone to your computer using a usb cable or card reader.. If you connect the phone there will be 2 extra drives in my computer. Right click on the memory card and click on format. Also choose the FAT32 file system while formatting it is more reilable. If you want to do this from a card reader a new USB drive will be shown in my computer. Right-click and format.
