Hi leeroyf - If the soap is not dispensing all the way out then usually the sprayer arms are not able to reach that area of the unit and door. I recommend making sure that the area is clean of dishes to try to prevent this issue because it sounds like something is blocking it and that the dispenser door is not stuck. Using the correct of amount of soap is also helpful. However, if problem proceeds then I suggest contacting a professional to move forward accurately since it may be having an issue with the wiring connections to dispenser and control.
