Lands Phones Logo
Posted on Nov 02, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need owners manual for ge answering machine by atlinks model no 29888GC1-A to set machine to answer phone after 3 rings.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • GE Master 102,366 Answers
  • Posted on Aug 19, 2014
GE Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428818
Points
622693
5 Related Answers
Anonymous
  • Posted on Aug 27, 2007
SOURCE: Storing Speed Dial Phone Nmbers
Quick Dial Numbers: 1. PICK-UP Hanset 2 PRESS STORE IN - DIAL Phone Number - PRESS STORE IN - PRESS A or B or C 3. HANG UP 4. WRITE name or number of party store in corresponding MEMORY location on Directory Card. Frequently Called Numbers: 1. PICK-UP Hanset 2 PRESS STORE IN - DIAL Phone Number - PRESS STORE IN - PRESS 1 to 9 (PRESS Memory Location Number) 3. HANG UP 4. WRITE name or number of party store in corresponding MEMORY location on Directory Card.
Anonymous
  • Posted on Dec 08, 2007
SOURCE: ge phone answering machine
The solution for the base (not the handset) is to press and hold for 2 seconds the "Skip" button (it's marked with ">>").
Anonymous
  • 84 Answers
  • Posted on Feb 14, 2008
SOURCE: changing the number of rings to answer on our Model 28112 GE Cordless phone
the voicemail ring count has to be setup on your phone line thru your voicemail menu,and has nothing to do with the answering machine. if you don't want the answering machine to pickup, just shut it off. follow the prompt's for your voicemail settings, there you'll be able to set the amount of rings you want.
hope this helps.
wg
Anonymous
  • Posted on Jul 22, 2008
SOURCE: ge phone/answering machie model #27851FE1-B
Press and hold the skip button. You will hear a voice telling you that the answering machine has been changed to English.
Anonymous
  • 371 Answers
  • Posted on Apr 18, 2009
SOURCE: phone won't ring with incoming calls
Thanks for your attention
2answers
Where do i find a manual for a ge cordless 900 Mhz model #26930ge2 Phone It is set in French.How do i change the language to English. Thanks
http://www.epartner.atlinks.com/Thomson_asia/GE/file.aspx?filename=GE/product_docs/26930-UserGuide.pdf
How i can set up only 3 rings before going to answering machine?
Use the RINGS TO ANSWER switch on the back of the base to set the number of times you want the phone to ring before the answering system answers the call. You may choose 3 rings, 5 rings, or TOLL SAVER (TS).
You can download the manual at
http://www.home-electronics.net/ge/pc/IB/25952EE1_IB.pdf
Howdo iset answer machine model no. 29888gc1-A sn 40542313i do not have an operation manual my email is [email protected]
http://www.home-electronics.net/USER-GUIDES/29888_DOM_EN_AN_IB.pdf
3helpful
I want to change the nombers of the rings to get start the answering machin
These are the instructions from the manual, which I found here:
http://safemanuals.com/user-guide-instructions-owner-manual/GE/21028GE3-A-_E
RING SELECT (FOR ANSWERING MACHINE)
This feature lets you select the number of times you want to phone to ring
before the answering system answers a call.
1. Make sure your phone is OFF (not in talk mode).
2. Press the MUTE/PROG button to go to the main menu.
3. Press CID/VOL (up or down) button to scroll to HANDSET SETUP.
4. Press MUTE/PROG button to confirm.
5. Press the CID/VOL (up or down) button to scroll to the RING SELECT menu.
6. Press MUTE/PROG button to enter the menu. RING SELECT 3 4 5 6 TS shows in the display.
7. Use the CID/VOL (up or down) button to scroll to the your selection. The default setting is 5.
8. Press the MUTE/PROG button to confirm. You will hear a confirmation tone and the new setting shows in the display.
NOTE: If you select Toll Saver (TS) the unit answers after the 3rd ring if there
are NEW messages, OR the unit answers after the 5th ring if there are NO new
messages. This allows user to access their answerer from another location and
then hang up after 4 rings to save long distance charges.
1helpful
How do you set the number of times the phone rings before the machine picks up on my GE answering machine? I can not find the manual
Hi kcee
I think I did find the manual here :
http://157.254.235.130/public/347A8329-0001 (Rev. 1 E&S).pdf
and here :
http://phone.manualsonline.com/manuals/mfg/ge_appliances/29827.html
you can find more types here :
http://phone.manualsonline.com/manuals/mfg/ge_appliances/ge_appliances_answering_machine_product_list.html
You can find General Electric home page here:
http://www.geappliances.com/electronics/
I suggest you contact GE on the link to get the manual and understanding your answer machine with a reply :
http://www.geappliances.com/service_and_support/contact/form_operating.htm
FOR Thomson Consumer Electronics :
you get there homepage here :
I did try to find the manual for your specific phone, but could only find these answer machines here (previous and next model number) :
http://www.home-electronics.net/ge/pc/IB/29871GE3_IB.pdf
http://www.home-electronics.net/ge/pc/IB/29869GE2_IB.pdf
source :
http://www.home-electronics.net/ge/pc/user-manuals.asp
on the second manual here on page 9 you find the settings to answer. I think they have used the same shortcuts for these models. They write ;
### This feature is used to set the unit to answer a call after
a specific number of rings.
The unit announces the rings to answer. To change,
press NEXT or PREVIOUS. To set and go on to the next
item, press SET.
1. Press and release NEXT or PREVIOUS until the unit
announces and displays the correct number of rings
for the answerer to pick up.
2. Once the rings to answer is set, press SET. The unit
announces the rings to answer, then enters the
incoming message length menu.
TOLL SAVER
The toll saver is the final setting in the Rings to Answer..........####
For the GE model you find these features on page 17
One last thing, you can contact Thomson Consumer Electronics for more specific answer or get the manual here :
http://www.home-electronics.net/ge/pc/contact.asp
they have also a phone :
"For customer service assistance, dial 1.800.448.0329. Our hours of operation are Monday thru Friday, 8am to 8pm Eastern, Saturday and Sunday 10am to 7pm Eastern."
Hope that helps
IF NOT then try to return here
Have a nice time over there
Please rate my answer
I have a GE 2.4ghz answering machine, model Atlinks USA, Inc. model number 27995ge1-a. We lost power to the phone and when the power came back, the answering maching is now speaking spanish. How do I...
1. Press the FLASH/program button until 1ENG 2FRA 3ESP shows in the display.
2. Use the CID/VOL (left or right arrow) button or the handset number pad to
select 1 (English), 2 (French), or 3 (Spanish). The default setting is "1ENG".
3. Press the FLASH/program button to confirm and to advance to the next menu
feature.
http://www.home-electronics.net/USER-GUIDES/27995_DOM_EN_CL_IB.pdf
Can not find manual
Well, yes and no. The 29888 does not come up in the current database. Here's a link to GE's website in the U.S. You might be able to describe your set or find something close to it. I'm guessing that all GE's in that group are similar.
Carl
2helpful
Need to shorten the amount of rings before it answers.
http://www.home-electronics.net/ge/pc/IB/27851GE1_IB.pdf
Top GE Lands Phones Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
