Hi FH error indicates no water detected entering the
machine or pressure switch trip not detected. If after 30 seconds the control does not detect water
entering machine and then valves will be turned off and the error code will be
displayed. It can also happen if the control has turned the water valves on and
after 8 minutes the flow meter has detected 10.5 gallons of water passing
through it, but has not detected the pressure switch trip, the valves will be
turned off and the error code will flash. You'll need to Press PAUSE/CANCEL twice to
clear the display. Please post a comment if you need more
help. Thanks Rylee
