Hi F09 error occurs due to overflow condition, if the
overflow contact on the pressure switch is closed for more than 60 seconds and
overflow condition will occur. To start with check the drain hose and make sure
it is not clogged, also try to clean the drain pump filter. If everything is
fine and the drain pump is running then check the wire harness to the drain
pump and control unit. Please post a comment if you need more help. Thanks Rylee
