Question about Konica Minolta bizhub C250 All-In-One Laser Printer
Scanning 2 page document
When I scan a 2 page document each page is emailed individually instead of 1 document with 2 pages.
Go into the PDS settings and change tab from single page to multiple page.
Posted on Jun 12, 2008
Anonymous
SOURCE:
I cannot figure out how to scan multiple pages into one document using my hp envy 5530 and then send them in my AOL email as an attachment
I do this by:
1. Scanning each document and printing each one to a pdf file (using the free doPDF prgrame from http://www.dopdf.com/)
2. Merge the individual pdf files into one pdf file using PDFtk (from http://www.pdflabs.com/tools/pdftk-the-pdf-toolkit/)
3. send the merged file
Hope this helps.
Dec 18, 2013 | HP Photosmart C3180 All-In-One InkJet...
Bothers MCF-490CW 4 in 1 || scanner - when scanning multiple pages, what must I do so when I send as an attachment the attachment is one group instead of each individual sheet?
Create a WORD document then paste each images on a page, save the Word document and then send this Word document as an attachment in your e-mail.
If you do net want to send the Word document then you can create a PDF of the Word document and send the PDF file as an attachment.
Jun 06, 2011 | Office Equipment & Supplies
I have a Kodak AIO 5 printer and Windows 7. I
This is easily accomplished using Kodak AIO Home Center v5.3:
Scanning documents from Home Center
1 On the main screen, click Scan Documents and Pictures.
2 Place your original document face down on the scanner glass.
3 Select Document.
4 Select the type of document you are scanning.
5 Select a Resolution for your scan from the drop-down list.
6 Select Perfect Page Technology to automatically correct imperfections in the scan.
7 Select Next.
8 On the Edit screen, edit each image as needed.
9 Click Next.
10 Select Save to File, then select Save As (pdf or rtf), Then Save.
11 Select Done to return to the main menu.
Jul 21, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
I seem to have a problem scanning on the KM C351. When scanning a multiple page document I recieve 1 .pdf file per page. This happens whether or not Seperate Scan is selected. Right now the scan are sent...
the file type is set to single page
1.press the scan button on the control panel
2.select scan setting.
3.select file type.
4.select multi page to have the entire scan to be sent as a single file.
if you are sending jpegs they can only be sent as single page files on this machine. only pdf's and tiffs can be sent as multi page files
Nov 13, 2009 | Konica Minolta bizhub C351 All-In-One...
I cannot scan a document to a single email
file type is probably set to single page. to set the file type to multi page do the following:
1.press the scan button on the op panel
3.select file type
4.select multi page multi page to have the entire scan job sent as a single file.
if you are scanning jpeg as file type they will only scan as single page docs only pdf and tiff can be sent as multi page files
Sep 18, 2009 | Konica Minolta bizhub C250 All-In-One...
Scan 5 pages. I go to email I have 5 seperate
you can do that by following steps 1.scanning all that pages and save them as different files in your computer. 2. open a word document and copy all the contents of the five different files and paste them in the word doc and save it 3. while mailing you can attach this word document to send all the files as a single attachment
Jul 21, 2009 | Dell Office Equipment & Supplies
Scan multiple pages to email
Do you have Microsoft Office?? If you do try this:
First, gather the paper you want to scan. If your scanner has anADF, you can load a stack of pages at a time. The first time you scan,Document Imaging detects the ADF for you.For more information about the ADF and whether your scanner has one,see the documentation that came with your scanner.
You will also want to sort your paper; if you have color pages thatyou want scanned in color, sort these in a separate stack from theblack and white pages. Load your first page, or first stack of pages(with an ADF) in your scanner.
Then, start Microsoft Office Document Scanning (the scanning component of the Microsoft Office Document Imaging program.)
  • On the Windows Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Scanning.
Tip If Microsoft Office Document Imaging is already running, you can start the scanning component by clicking Scan New Document on the File menu.
Set up your scanning optionsIn the Scan New Document dialog box, do one or more of the following:
  • To view your scanned file(s) in Document Imaging after they have been scanned (recommended), select the View file after scanning check box.
  • If your scanner is equipped with an ADF, click Scanner, and then select the Use automatic document feeder check box.
  • If your scanner is equipped with an ADF and you have double-sided originals, select the Original is double sidedcheck box to scan both the front and back of multiple pages. Place thepages in the feeder so that the page fronts are scanned first.The Microsoft Office Document Scanningdialog box will appear after each scan, allowing you to turn the pagesover and scan the page backs. Document Imaging automatically collatesthe pages in the correct order after scanning is complete.
  • If you have a true duplex ADF (one that automatically scans both sides of the page), do not select the Original is double sided check box. Instead, in the Scan New Document dialog box, click Scanner, and then select the Show scanner driver dialog before scanning check box. When your scanner driver dialog box appears during scanning, select the proper duplex settings.
  • If you want to scan pages manually, select the Prompt for additional pages check box. Office Document Imaging will pause after each page is scanned, allowing you to place the next page in your scanner.
  • By default, optical character recognition (OCR) is performed onyour document during the scanning process. Although performing OCR addstime to the scanning process, it also has the following benefits:
    • When you open the scanned document in Microsoft Office DocumentImaging, you can search for recognized text in the document, copyrecognized text in the document to another document or program, andsend recognized text in the document to Microsoft Word, withoutperforming OCR manually.
    • You can have your scanned files saved with an automatic filename based on the first words on the page (this is the default.)
    To turn off OCR during the scanning process (you can perform OCRmanually in the document in Document Imaging after scanning), do thefollowing:
    1. In the Scan New Document dialog box, select the preset you want to use, such as Black and white.
    2. Click Preset options, and then click either Create new preset (and then type a name for the preset), or click Edit selected preset.
    3. On the Processing tab in the Preset Options dialog box, clear the Use OCR to recognize the text of the scanned image check box.
Select location, name, or file type for the scanned filesPart of the scanning process is to save a scanned page to a file. Bydefault, when you scan multiple pages, the pages are saved in one file.If you want to save each scanned page as a separate file, select thenaming convention for the scanned files, or change the location or fileformat of the scanned files, do any of the following:
  3. Do one or more of the following:
    • To save each scanned page as a separate file, select the Save each page as a separate document check box on the Page tab.
    • To change the location for the saved files, click the Change button on the Output tab, and select a location.
    • To select the way the individual files will be automatically named, click one of the File Name options on the Output tab. (If you have turned off OCR during scanning, you will be unable to use the Auto name based on first words on page option.)
    • To select the file format the scanned pages will be saved in, click the Advanced button on the General tab, and select the options you want.
  4. Click OK.
Scan your pages
  1. In the Scan New Document dialog box, make sure the preset you want to use is selected, and then click Scan. If you selected the Original is double sided check box or the Prompt for additional pages check box, the Microsoft Office Document Scanningdialog box appears periodically to let you know that the scanner hasfinished. You then have the option to continue scanning (place anotherpage in a scanner that doesn't have an ADF) or turn your page or pagesover to scan the other side. Arrange your page or pages as desired, andselect the option you want to continue scanning.
  2. When all pages, all sides have been scanned, click Done in the Microsoft Office Document Scanning dialog box.
  3. To scan additional pages, review the Get started section above, and then repeat the instructions in this section (Scan your pages.)
Organize pages in the saved file(s)Now that you've finished scanning, it's time to take a look at theresults. If your scanned pages are not open in Document Imaging, do thefollowing:
  1. On the Start menu, point to All Programs (Programs in Windows 2000), point to Microsoft Office, point to Microsoft Office Tools, and then click Microsoft Office Document Imaging to start Document Imaging.
  2. In Document Imaging, click Open on the File menu.
  3. Locate the file you want to open (by default, the scanned page(s)is saved to the My Documents folder with an auto filename based on thefirst words on the page, such as Page1of.tif) and then click Open.
  4. Repeat steps 2-3 until all of the files you need are open.
You now have an online version of your stack of paper. Here are a few tips to get you started organizing pages.
  • Rearrange pages within a document In the thumbnail pane (thumbnail pane: Presents the current scanned document as one or more small images.), select one or more pages to move. Click any selected thumbnail and drag the selection to the new location in the thumbnail pane.
  • Copy a page to a new document In the thumbnail pane, select the page you want to copy. On the Page menu, click Copy Page. Switch to the Document Imaging document into which you want to insert the copied page. In the thumbnail pane, select the page that precedes the location where you want to paste the copied page. On the Page menu, click Paste Page.
  • Delete a page In the page pane or the thumbnail pane, click the page you want to delete. On the Page menu, click Delete Page.
For more information about scanning or organizing pages, see Microsoft Office Document Imaging Help.
The papers that were once cluttering your desk have now beentransformed into electronic documents. Within these documents, you canarrange pages, move pages to different documents, delete pages, printpages, add annotations, copy text to other Office programs, or send apage to someone in email. And still have room on your desk for yourcoffee.
Jan 27, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
SCANNING A DOCUMENT
the easiest way to scan a 20mpage doc or more is to opeb the paper port icon and then follow the prompts, this is easier then scanning from the printer good luck brother sr tech
Jan 12, 2009 | Brother MFC-8460N All-In-One Printer
Touble scanning more that one page as a document
If you are scanning using the Scan to PC button, the unit will scan as you described. In order to scan multiple pages into one document, you need to go go through the Smarthru software, or whatever scanning software your unit includes. Since your unit is manufactured by Xerox, you can go to www.samsung.com and download the SmartThru software of your choice for free.
Sep 16, 2008 | Samsung SCX 4521F All-In-One Laser Printer
Scanners
I bought a different printer.!!!
Aug 19, 2008 | Brother MultiFunction Center MFC-440CN...
Konica Minolta bizhub C250 All-In-One Laser Printer Logo
743 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
carpediemweb
Level 1 Expert
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
