Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
Posted on Oct 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
LD error on the Whirlpool Cabrio Washer. We are trying to remove the drum to remove items
Anonymous
Level 3:
  • Master 8,619 Answers
  • Posted on Nov 01, 2010
Anonymous
Master
Level 3:
Answers
8619
Questions
Helped
2149334
Points
26471
Hi
Ld error indicates long drain and flashes when the water level will not change even after the drain pump is on. To resolve this please make sure that the drain hose is not clogged and the pump is working. To gain access to the drain pump you can lay the machine on its front then remove the drain hose and replace the pump if the impeller has gone bad. Please post a comment if need more help.
Thanks
Rylee
1helpful
6200 whirlpool cabrio, Ld error code. Usually, cancel, start corrects problems. Now seems like it won't spin. Tried unplugging and restarting, that also didn't work.
most likely a clogged pump drain find it below the drum usually under a plastic lid bottom left if not under the lower panel below the door
find the 3 screws and remove the cover panel and clean the pump by twisting the pump valve cover counter clockwise
WHIRLPOOL CABRIO WASHER ERROR LD The Cabrio Washer LD error code stands for Long Drain which means the control has recognized the water in the tub is not draining fast enough during the cycle.
  1. Make sure the pump and drain hose are clear of debris that would cause a blockage.
  2. Check the impeller on the drain pump and make sure its not wobbly or busted.
  3. Remove the tub hose from the pump to the tub and check it for blockage.
  4. Make sure the pump is running when and getting the proper voltage when it should be.
  5. If all the above checks out then replace the drain pump motor.
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Whirlpool Cabrio Washer Error Codes & Repair Help
applianceassistant.com/Washer.../Cabrio-Bravo-Oasis-Error-Codes.php
Whirlpool Cabrio Washing Machine Error Code Problems, Diagnostics, ... Cabrio LdError Washer is taking too long to drain water from the washtub
Kenmore Elite Calypso Top Loading Washer - ApplianceBlog
www.applianceblog.com/.../1297-Kenmore-Elite-Calypso-Top-Loading-...
Sep 11, 2005 - 10 posts - ‎5 authors
My washing machine stopped after filling and won't wash, drain or spin. ... and then come up with either LD, FL Or SL code and stop working.
Whirl Pool Cabrio LD Temp fix pt.2 - YouTube
? 2:59
https://www.youtube.com/watch?v=tFBtD2wUj4g
Jun 21, 2009 - Uploaded by liquid131
Whirl Pool Cabrio LD Temp fix pt.2. animal131 ... How to override an error code on the Whirlpool Cabrio washer - Duration: 3:08. Whirlpool ...
4helpful
Get message LD. Won't drain. Removed clothes from washer but still won't go into drain mode.
Ur drain pump needs to be replaced. I just had this same issue with my whirlpool cabrio.LD means long drain.
1helpful
My whirlpool cabrio washer has ld code. have checked pump as well as inside the washer by taking basket out & nothing is plugged up. there was a small amount of water in drum when we removed basket....
Please see the following Whirlpool service manual for the Cabrio washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Ld flashes when the water level does not change after the drain pump is on.
• Is the drain hose or the drain pump clogged?
• Is the drain hose height greater than 96˝ ?
• Is the pump running? If not, see TEST #7.
My Whirlpool Cabrio (WTW6600SW1) drains completely then Ld error!
I have a call with the same problem. Pumps all the water out but still flashes LD. Should be the board, The electronic pressure switch is built in to the board. Make sure the pressure chamber on the back right side is not cloged
5helpful
LD is on my display-nothing will clear it and washer doesnt drain
the ld code means a long drain, what you probably have is something blocking the drain pump.
you can get to the drain pump from the back of the unit and it will be the pump on the left as you face the back.
you will need to remove the hose going into the pump and be ready for water to come out. sorry but you need to check inside the hose as there will be something blocking it. like a coin or some lint or a small sock.
when you get the item out of the hose then it should work again. you do not need to reset the control. once it knows the unit is draining properly it will be ok.
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
