Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Model # 106.56533400 has a bad smell. how do you take the drip pan out? if this is not the problem what else could we check. we have cleaned everything out and washed it thouroughly. it is about 5 years old-is there any warrantyi? We had a sears repairman out and the problem is still there. Cost about $100 and the problem is still there. please help.
    Top Expert:
  • Kenmore Master
  • 66,072 Answers
NO WARRANTY . try BAKING SODA
Posted on Sep 25, 2017
6ya staff
SOURCE:
Anonymous
  • 8 Answers
SOURCE: kenmore side by side model 596.55662500
have you tried pouring bleach water through the drains in the fridge?
Posted on Nov 08, 2007
Anonymous
  • 33 Answers
SOURCE: Cannot remove drip pan
im sorry but that drip pan cannot be removed you might have to do the best you can with it in there.
Posted on Jan 03, 2008
CRTN
Michael Fisher
  • 716 Answers
SOURCE: terrible smell coming from bottom of unit
There Should Be A Grill On The Front Bottom Below The Door. Remove That And It Should Come Out Of The Right Side.
Posted on Jan 05, 2009
Anonymous
  • 531 Answers
SOURCE: Can't find drip pan and have a really bad smell
drip pan is on top of compressor
Posted on Apr 07, 2009
Bat1956
Bruce Volkers
  • 585 Answers
SOURCE: drip pan needs emptying; had repairman out for other issues, now fridge keeps overflowing
The accumulated ice you saw is of course the source of the water. The refrigerator will eventually rid itself of the excess ice and the problem will therefore disappear on it's own after a while. The drip pan is normally filled with only a small amount of water, and that is dried up by the condenser cooling fan under the fridge. The pan is removable from most units, but not without making a mess. I suppose you can make and clean up the mess one time and be done with it.
Posted on May 20, 2009
The drain pan under my refrigerator stinks really bad how can i remove it to clean it
The drain pan can be removed by lifting up the refrigerator and removing the four torex screws on the bottom of each side of the refrigerator. Use 2 pieces of 2x4 to hold up each side of the fridge while removing these screws. After removing the screws the bottom panel will separate from the refrigerator and you can remove the drip pan from the panel as it isn't attached by screws. The pan is VERY fragile and removing the drip pan is a two person job. I recommend just pouring bleach into the drip pan to kill any bacteria causing the smell by removing the back panel which will be held on by several quarter inch screws. You'll see the white drip pan on the right hand side of the fridge looking from the back.
Aug 06, 2011 | Refrigerators
I have a Whirlpool refrigerator 21TFA that may have a drain problem or a clog. It drains in the evening, but this morning when I woke up, it smelled bad from the bottom of the refrigerator. Any advice?
Hi and Welcome to FixYa I am Kelly,
A bad smell from under the refrigerator is a result of either a dead rodent or.. dirt and lint accumulation in the plastic drip pan / catch basin and then the defrost cycle water wets it 2 to 3 times a day intensifying the smell.
Unplug the unit
Remove the rear fiberboard cover that covers the compressor area
Use a shop vac and rags to clean out the drip pan / catch basin. (These can be VERY foul if they have never been cleaned!) Make sure to clean the condenser coils and condenser fan area also. Inspect for varmits / rodents (deceased) with a flashlight. You can wash the drip pan using a rag with vinegar and water then soap and water.
Lastly... make sure the END of the drain tube that terminates in the drip pan is clean. If there was lint build up that caused a muck pool in your drip pan the muck often clogs the end of the drain line.
You never know what your going to find under a refrigerator! I could expound but it is not pleasant and only you will be able to discover the secrets of your refrigerators' "underside life." All I will say is.. it is always a... revealing experience.
Thanks for choosing FixYa,
Kelly
Mar 21, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Smell fish odor when fan comes on.
Tim, Clean the refrigerator completely with clorox and water. Unplug and remove the rear panel in the back of refrigerator and wash the evaporator coil with this solution. Check the amount of flow to the condensate pan below. The drain line has the gel and this contaminated smell from top to bottom and you will need to insure that all the smell remaining in the drain is draining freely and decontaminated with the clorox. Do these things and wash the remaining pan below the best you can and you will be set to go.
Jun 20, 2009 | Whirlpool GD2SHGX Refrigerator
Bad odor coming from drip pan when compressor kicks own[when dry]
I just had the same problem with my kenmore side by side. I have been noticing a nasty smell for the last couple weeks when the fan comes on. My husband just took the whole back of the refrigerator apart and put a flashlight in there. We could see the drip-pan and it was filled with stinky black mold!! It was very hard to remove, but he managed to get it out by taking the lower front (where the filter goes) apart and then he was able to slide out the drip pan and clean it out! Problem solved.....but Kenmore should really make the drip pan more accessable!
Apr 12, 2009 | Frigidaire FRS26ZSG
Odor
Replace your water filter and totally clean your icemaker. Check the drip pan under the unit if you can smell it through the whole house. You have more than an icemaker issue.
Apr 12, 2009 | KitchenAid KSRG25FKSS Side by Side...
Fridge problem
usually the smell is the water dripping into the pan under unit place cleaners and use charcoal inside unit to remove odars that collect on evaporator and get concentrated then go to drip pan
Feb 11, 2008 | Frigidaire FRT17G4B Top Freezer...
Kenmore side by side model 596.55662500
Nov 08, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I cannot get to the drip pan under refridgerator to empty it. It is filled with sludge and smells bad
Thank willie for helping with one: "Well, it looks like the pan is a seperate plastic pan and not the compressor mounting pan like some of the newer ones are. It appears that you have to remove the condensor fan motor and mounting bracket then maybe the pan will left up and over the compressor, or maybe there is enough room to lift the pan up and out the front over the condensor coils"
Jun 04, 2006 | Amana Easy Reach AFD2535DE Bottom Freezer...
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
106 people viewed this question
Top Kenmore Refrigerators Experts
Jimmy
geob91
John Tripp
John Tripp
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
