NO OS stated of the 14 possible from MS or 100s from linux.
why post not with that? first, after all drivers match OS always.
watch out some HP desktops run a digital front panel.
so if that is missing , the card house falls. mine has it,
such that when front is missing rears die. (by design)
real 3.5mm head phones, buds or real speaker tried yet?
no statement as to what was plugged in to the green jack
if in fact they had green in 2003 or older.(it wasnt in the beginning with color codes )
no sound form control panel sound, sound tab ,green arrow?
and play say critcal stop (see wav file there) this is test 1.
no statement at all on source of sound,. the CD needs special audio cable to make CD do sound. so......
do the wave test above, first. if that works tell the helper more.
if the DM driver is ok in device manager.?
the green jack is line out and needs an amp or amplified speaker
or phones, no direct drive 8 ohms speakers work there(externals)
no SB card model stated, is it 17 years old or older, be super hard to make that work in 2017, !
lest me ask first is there USB headphones is used, if yes, bad.
remove it.
now i'll read your manual fast. its 2003 relic why hp as page on it still i dont know but get em while there. still hint hint.
this old pC came with
O/S2 or windows
and w98/2k/xp/vista
and each has its own drivers at HP link below.
sad I have to guess.
now I know why the pages are not deleted yet, VISTA
support is it.
if not VISTA, lick the CHANGE button below.
https://support.hp.com/us-en/drivers/selfservice/hp-compaq-d530-small-form-factor-desktop-pc/316713
i refuse to talk Sound blaster, unless you tell model.
and what you are playing
OS
and what is in the USB jacks and the green 3.5mm jacks.
sorry
Go to the web page for the mother board and download the audio driver for it
or go to the web page for the sound blaster card and down load the driver for it from there
SOURCE: HP Compaq d530 SFF PC Desktop Problem - Graphics card: Updgrade
Try this site:
http://www.geeks.com/products.asp?cat=VCD
The ATI Radeon HD 2400 256MB PCI-Express VCD w/TV-Out DVI seems to me to be what you are looking for..
Good Luck!
SOURCE: hp compaq d530 CMT motherboard diagram
You are missing the front headphone / microphone connector that plugs into the motherboard. Or a way to jump this to close the headphones so the sound will come out the back.
SOURCE: hp compaq driver d530 sff
I found the drivers I needed at http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=316715&lang=en&cc=us&prodTypeId=12454&prodSeriesId=316713&taskId=135
I am running XP and used SoundMax Integrated Digital Audio for audio &
Intel Graphics Driver for Microsoft Windows 2000/XP for video.
SOURCE: HP D530 SFF CHASIS FAN NOT DETECTED
Should be an alarm setting, usually in the bios, for both chassis intrution and fan and cpu warnings. disable it and no error message.
Most likely the fan power is connected to the wrong fan port on the motherboard itself and placing it on the correct port will fix the issue.
SOURCE: ethernet driver for hp compaq d530
Drivers are located here: http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=316715&lang=en&cc=us&prodTypeId=12454&prodSeriesId=316713&taskId=135
You must select the appropriate operating system for your application
