SOURCE: Garmin Nuvi 350 Touch Screen unresponsive
The touch screen lays on top of the LCD display. It has its own flex cable that plugs into the main board. It is possible for the LCD display to work fine while the touch screen does not. They are two separate parts and work independently!
If your touch screen all of a sudden quit working, I would ask did you ever drop it?
I have repaired many Nuvi's with a non-functioning touch screen. I can't speak for every instance but the ones i took apart, the flex screen cable was loose from the main board.
Don't attempt to fix this yourself unless you know what your doing. Email me at ks3r at sharc dot net if your interested in me repairing your Nuvi at a reasonable price. I have references.
- Jim
SOURCE: how to register a garmin nuvi 205w
go to: https://my.garmin.com/mygarmin/marketing/register.htm
SOURCE: nuvi 205w LCD screen replacement needed.
Your only reasonable solutions are:
1) Send it back to Garmin for repair, which will probably cost you more than the unit is worth, or...
2) Check CraigsList or other places for good deals. The prices on these things have been in nose-dive mode for months and you're liable to find a very good deal for very little money. (I just bought a StreetPilot C330 for $50 from CraigsList last week.)
SOURCE: garmin 205w nuvi cannot unlock
Ok so I decided I was going to return this thing tomorrow after hours of frustration, so I decided to get crazy with it and then figured out something that seems to have worked (will probably still exchange it for a Magellan or something other than Garmin though).
It's gonna sound crazy, but I opened up the Garmin drive on my computer (Mac, so not sure how this works on PC), and deleted everything I could see (not hidden files). EVERYTHING.
I then went ran Disk Utility and reformated the "Hard Drive" (on PC I would guess your able to do the same somehow). It still ran after that, but obviously could not find maps (since I just wiped every trace of a map away).
Next step, I ran Garmin Map Manager and transfered map for my state (AZ) (I have the latest map update saved on my computer, so I'm guessing Manager used that). Unplugged from comp, powered up, and voila! I will need to download my voices and vehicles again, but hey at least it's working again.
The Garmin Nuvi 205W and most other 200 series GPS receivers are normally reset as follows:
The reset button is located on the right rear-backside of the unit. Press a blunt non-metallic object or a cut off toothpick into the small hole and hold for approximately 15 seconds. The unit should do a fresh reboot. Sometimes these GPS units can be reset by sliding the Power key to the left for 10-15 seconds to completely shut the unit down. Then, do the same procedure for 10-15 seconds again, to power it back on.
It would be best to assure the unit has external power, and hopefully a full battery charge, for best results. Also you can download a complete manual from this link for more info:
http://www8.garmin.com/manuals/nuvi205_OwnersManual.pdf
Let me know how this turns out, and if I can help you further.
Regards, Bill
