Question about Mtd #TB4SC 25CC 4-Cycle Gas Blower
I can't find English version of MTD BV3100 blower vac. manual. Is the oil to petrol 1 litre to 25ml?
  • 760 Answers
Http://manuals.mtdproducts.com/mtd/Safety.do?pid=220901&model_num=bv3100&serial_num=1212&filename=bv3100_769-01600_a.pdf
http://manuals.mtdproducts.com/mtd/Safety.do?pid=220902&model_num=bv3100&serial_num=1212&filename=bv3100_769-01601_b.pdf
The manual says 5 liters to 125 ml so yes if you divide by 5,that is equal to 1liter to 25ml That is a 40:1 ratio.
Posted on Oct 31, 2010
6ya staff
SOURCE:
What is the fuel and oil mix ratio
Depends on what the tool motor calls for premix wise.
Premis oil comes in premeasured container based on a 2.5 g or 5gal mix of gasoline to one small container of pre-mix oil.
Have safe fun, wear your eye protection.
Kelly
San Diego, CA
Aug 30, 2014 | Garden
For a yamaha outboard motor 2 stroke , how much oil would be added to 12 litres of fuel
50 litres petrol:1 litre Outboard TCW3 OIl
100litres petrol:1 litre Outboard TCW3
@ 50:1 You Would Put 240Mls Oil In 12 Litres Petrol
@ 100:1 You Woul Put 120Mls Oil In 12 Litres Petrol
Mar 12, 2013 | Boating
Is it 25/1 petrol and oil for a sthil blower bg85 thanks
hi artwill3544
no
using sthil 2 stroke oil mix at the rate of 50:1 that is 20 mils of oil per 1.0 litre of petrol that you mix , or if you mix 5 litres you would pour in 100 mils of 2 stroke oil into a 5 litre petrol petrol can , then add 5 litres of petrol only and give good shake to mix , then fill your blower with that mix
cheers pauly46
Sep 21, 2011 | Garden
What fuel mix for a JCB M25 Strimmer?
40:1. Which works out at 25mls of oil to every litre of petrol.
Found the above answer on another site, 40:1 in the U.S. is 2.6 oz. of 2 cycle oil to 1 gallon of gas.
Sep 04, 2011 | Garden
How much oil does the sump require in a talon AM3050 lawn mower? Can't find my manual
It's very difficult to find information for this specific mower, however, most petrol mowers have a reservoir size of 1 pint / 0.5 litre. You should have a dipstick for checking the oil level anyway.
Basically, I suggest you drain the sump and add 0.5 litres of oil to ensure that the machine is neither low on oil or overfilled. Then call/email the manufacturer on Monday for clarification and/or a new manual.
Talon Tools contact:
tel: 1300 804 213
customerservice@husqvarna.com.au
Regards,
BElectric
Nov 06, 2010 | Mtd 22" Yard Machine Push Mower
What type of oil does the poulan pro BVM 200 EL use and is the gas:oil ratio 40:1?
use - husqvarna , sthil brands high quality 2 stroke oil
as directed on bottle 50:1 that is 20 mils of oil for every 1.0 litre of petrol that you use
if you want 2 litres mix put in 40 mils of oil into petrol container
then put in 2 litres of petrol only and give good shake and fill the blower
cheers
Sep 01, 2010 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
I have a MTD blower vacuum model BV3100 and require a new collection bag
Buy a Homelite Large bag from Bunnings it fits snugly using Velcro strap to fix to vacuam uptake 243d5733-f67f-465c-b8f0-725d16356882.jpg
Aug 20, 2010 | Mtd Products 32 CC, 4-Cycle Backpack...
Someone just gave me a Craftsman 32cc blower without the manual. What fuel does this use?
IF it says 4 CYCLE then it uses regular gas.(87-89 octane unleaded) Another sign to prove it's 4 cycle it should have a crankcase you keep filled with oil.
Jul 18, 2010 | Craftsman 4 Cycle Blower/Vac
Mtd #TB4SC 25CC 4-Cycle Gas Blower Logo
201 people viewed this question
Top Mtd Garden Experts
dannydoesita
Joseph Mueller
Joseph Mueller
p38arover
Level 1 Expert
Are you a Mtd Garden Expert? Answer questions, earn points and help others
