In this link you have the info.:
http://www.pctechbytes.com/networking/how-to-configure-a-linksys-wrt54g-router
Access the Admin site of yout router
http://192.168.1.1
default authentication
user: blank
password: admin
after login, click administration. then setup the new password
eric
Hello.
Do you need the wireless password or the router login password?
If you need wireless
password(security key like WEP or WPA) or you would like to setup
wireless security for your Netgear router, access the router setup page by
typing http://192.168.0.1) in the address field of
your browser and then press Enter.
Enter admin for the router user name and your password (or the default, password).
This image is a sample of the login window to access the router's setup page.
After logging in. Look at the main menu
on the left, click on Wireless Settings, from there you
can check the Wireless Key(usually indicated
as "passphrase") or
you can setup wireless security from there if you haven't done so.
This image is the router's setup page and this is where you can
configure the router and check some settings like Wireless security or
password.
**If by chance you are unable to access
the router's login or setup page by using the default username &password(admin, password) and you totally
have forgotten it, you need to reset the router to factory or default settings
then you have to setup the router again.
**To reset the router to default settings:
1. Unplug all the cables attached to
it except the power cord. - Make sure the
router is plugged into the power outlet, then hold down the reset button at the
back of the router for 30 seconds using a paper clip or a pen. You should see
the lights flicker momentarily on the front panel of the router.
2. Once the lights are stable, connect 1 computer or laptop directly to the
back of the router(Ethernet/LAN ports usually they are labelled by numbers and
have the same color, just pick one). If you pick number 1, check the
corresponding light indicator at the front panel of the router, make sure light
1 is also lit up if not choose another port at the back of the router.3. Setup
and configure the router again.
~~Hope this helps~~
After logging in. Look at the main menu on the left, click on Wireless Settings, from there you can check the Wireless Key(usually indicated as "passphrase") or you can setup wireless security from
This image is the router's setup page and this is where you can configure the router and check some settings like Wireless security or password.
**If by chance you are unable to access the router's login or setup page by using the default username &password(admin, password) and you totally have forgotten it, you need to reset the router to factory or default settings then you have to setup the router again.
**To reset the router to default settings:1. Unplug all the cables attached to it except the power cord. - Make sure the router is plugged into the power outlet, then hold down the reset button at the back of the router for 30 seconds using a paper clip or a pen. You should see the lights flicker momentarily on the front panel of the router.
2. Once the lights are stable, connect 1 computer or laptop directly to the back of the router(Ethernet/LAN ports usually they are labelled by numbers and have the same color, just pick one). If you pick number 1, check the corresponding light indicator at the front panel of the router, make sure light 1 is also lit up if not choose another port at the back of the router.3. Setup and configure the router again.
Hope this helps. Have a nice day.
My friend,
You have to lo-gin
into the router setup page .
1.Put this address (192.168.1.1)
in the address bar and then you will see the router setup
page.
2.Then this will ask you for the username and
password.
3.Username is nothing so leave this blank and password
is admin.
4.Then you will see the router setup page .
5.Click
on the wireless Tab near the basic wireless settings you will see
wireless security .
6.Click on the wireless security and you
will see there your router wireless security mode.
7.Always select
Security
Mode as WPA2 PERSONAL.
8.Enter the key which you want to setup.
9.After changing the
settings Click on the save settings.
Regards:-
Amit
Awasthi
Related Articles:
Setting-Up WEP, WPA or WPA2 Wireless Security on a Router
Checking the Wireless Settings on a Linksys Router
Downloading at Linksys by Cisco Support Site
