Mark Batteries your charger is putting our enuf 13.15 volts for each battery so after charging all night you should be reading about 13 volts on each. If your batts are only 12 volts after all night charge then batteries are weak Hope this helps
Testimonial: "Thanks very much! I wa not sure if the charger was outputting enough voltage to charge the batts, You have confirmed that the batts need replacement"
