The tv in the cabinet could be fixed. First check the mains fuse. It sounds to me that the internal power supply board fuse has blown, to access this you will need to access the back, once you have access to the insides of the set where the power cord enters the set you will find a small somtimes coloured fuse set in a small fuse holder, pop it out, take to your local electrical shop and you should be able to find the same rating fuse, and the good news is that they are only cheap. Make sure you get the exact rating fuse to replace the old one.
With regards to the cabinet if the above dos'nt fix the set, then yes it would be possible to put another set into the cabinet, but you would probably find you would have to do alot of modifications yourself to fit another set, you would have to find the screen dimentions, and need to be able to secure the set properly. hope this helps a bit and post back if you manage to get the set going again. thanks.
Yeah it's work fixing, if ever you know a repair shop you can trust just talk to one of their technician to service it at home.
