Question about Philips Televison & Video
I have a phillips progressive scan dvd player model dvd622/37. It was working fine, until i went into the system menu and clicked on something my tv doesn't support......when i turn on my dvd player, i get a scrambled picture, can't see anything, plz help me to reset my dvdv player....ty
  • BigDirt Jun 11, 2008
    no it wasn't helpful ..i messed up somethinh to do with video, in the system menu...can't see anything but purple scramble, instead of getting my dvd screen, with or without dvdv disc
    i'll try back, when i can use a credit card thx, or just get a new one
    Problem Solver:
  • 12 Answers
I made the same mess myself. The way to get around it is to program blind - meaning that you do not get to see the screen to see whether what you did is right or not.
Put on the device. Press system key, press arrow key until you hit video, press ok, scroll down one key press and then press ok. You should start getting a coherent picture and then you may finetune.
Best of luck.
Rangan - Mumbai
Posted on Jun 02, 2009
    Genius:
  • Philips Master
  • 1,550 Answers
On the phillips Dvd turn on the device get the tray open press button arrow to the right and mute on the control.With this the scan get deactivated.Good luck
Posted on Jun 11, 2008
6ya staff
SOURCE:
My memorex combo dvd & vhs player is not working right. can you help me? the vhs player works fine, but the dvd player display's a split screen on the tv with a large yellow box with the word PSCAN....
PSCAN is a short form for Progressive Scan - a line scanning format used for High Definition TV. Standard TVs use Interlaced scanning. On your DVD/VHS player, the VHS is an analogue signal recorded in interlaced mode so is fine for a standard TV. The DVD is a digital signal and cazn be processed for progressive scan output in order to produce a better picture on a High definition TV (or a TV capable of handling progressive scan). If you cannot to your TV via the HD outputs then you should be able to set the DVD player to output interlaced instead of progressive scan.
Mar 05, 2011 | Memorex MVD4540 DVD Player/VCR
RDR-GX315 was accidentally reverted to "Factory Settings" ... now we can get sound but no picture and progressive is turned on and we need to turn it off.
If your TV has progressive scan capability, you may be able to view the on-screen setup menu via the recorder - select 'SETUP' press 'ENTER' on your DVD recorder's remote to bring up the menu - with the remote arrow buttons, scroll down to select 'VIDEO' then 'PROGRESSIVE' - highlight it then set it to OFF (you cannot do this with a TV that does not support progressive scan from this unit). Once done, exit the setup menu and it should work fine with all the other settings. If your TV doesn't have progressive scan, connect the DVD recorder to one which does and turn its progressive output off there. I assume you still have the user manual for your recorder (if not, you can download it online for free as an Adobe document - .pdf. Page 73 details the setup steps for this model). I hope this tip helps somewhat.
Feb 11, 2011 | Sony RDR-GX315 DVD Recorder
I have a HD TV with cable and a go video DVD/VHS player hooked up. I went to change the time and accidentally changed the setting on the DVD player from auto scan (I think) from off to on and now when I...
It sounds like you may have enabled the progressive scan output on your DVD-VHS combo. This is a correct setting if your TV support it. However most DVD players that support progressive scan will not support an interlaced signal and a progressive signal at the same time.
It would appear that you are using a composite type cable (3 RCA ends. 1 for video and 2 for audio) for this hook up. This means you have two choices.
#1 Look in the manual for the unit for the FACTORY Reset option. Its usually a combination of plugging the unit in while holding the power button or something similar to that. Without a model # I can't help any further with this option.
#2 Use a component video cable (3 RCA red/green/blue) to plug your DVD/VHS player into a compatible input on your HD TV. Your TV will pick up the progressive scan output from the unit and give you back your on screen display. At this point you can go back into the menu and disable progressive scan. And now just reverse the process to plug the DVD player back in using the composite cable.
It should be noted that if you have a progressive scan TV which HD TV's support you will get a better picture if you use the Component video cables instead of switching back to the composite cable. If you decide to use the component cables you will still need to run audio cables though.
Best of luck.
Trevor
Aug 11, 2009 | GoVideo Go Video DVD/VCR Combo
Oritron dvd 3119 player
after unsuccessfully trying to naviagate the menu , i unplugged the dvd player for 10 or 15 min. then plugged it in again and changed the output i had it plugged into,,from video 1 to video 2 and i got my picture back it seems fine now
Apr 03, 2008 | Oritron NPD3117 DVD Player
Split screen from DVD player, cable is fine no problem
The progressive scan can work only throug progressive scan CTV.. while some of the newest DVD player today has a progrissive... now you must turn OFF the progressive scanof your DVD on the set-up menu to see the real screen display.
Jan 07, 2008 | Televison & Video
Progressive Scan
Please go to the following link for an exact definition and how it is applicable to your situation. Please read all 3 pages of information!!!!! The short of it is, is that your TV may not be set up for progressive scan. Try turning off progressive scan on your DVD player's menu and see if this works.
http://hometheater.about.com/od/beforeyoubuy/a/progressivescan.htm
Jan 03, 2008 | TruTech TT1620 DVD Recorder
DVD sound but no picture...after pushing progressive scan button
desactivate the progressive scan or if u don't know how to do it, just do a reset on the dvd player.
Dec 29, 2007 | Samsung DVD-V4600 DVD Player/VCR
Help
Go to menu and sub menu video .Under video option you will see video formatt,e.g Pal,NTSC.You confrim your tv standered if its pal or NTSC (this you can check at back of your tv set ,not always mention but most of them are printed)On your dvd player
you have to select same formatt as your tv .If not sure of you tv system try auto system on you player.
NB dont select progressive scan by mistake otherwise you will not see any picture on your tv if its not progressive scan tv.
If you could mention tv and dvd model and brand will be able to advise you exactly.
Dec 13, 2007 | Televison & Video
How do you take progressive scan off
eject the tray and press the stop button for 5 - 10 seconds...if not stop then try pause button
Nov 17, 2007 | TruTech TT320
How do I turn off Progressive scan?
Hi, follow the steps it may help !! Press STOP button. ? If playing a disc, press the STOP button twice so that ?STOP?, appears on the display. Press and hold P.SCAN button on the remote control for over 5 seconds. ? Pressing and holding the button for over 5 seconds will select "Progressive Scan" and "Interlace Scan" alternately. ? When you select P.SCAN, "P.SCAN" will appear on the display. ? To set P.Scan mode for DivX discs, press the P.SCAN button on the remote control for more than 5 seconds with no disc in the unit (?'NO DISC" on the display), then load the DivX disc and play. regards sreejith
Jul 17, 2007 | Progressive DVHE210 210 DVD Player
Televison & Video Logo
125 people viewed this question
Top Philips Televison & Video Experts
ThaMp3Doctor
ThaMp3Doctor
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
