I have washing machine hotpoint model wm71n showing error code E30 and washing machine rund for one minute then stops, please tell me what i should do.
    New Friend:
Mine has just donethe same today have you had the solution yet please
Posted on Nov 23, 2010
  • Washing Mach... Master
  • 3,463 Answers
Error code E30 generally indicates a problem with the motor.
Check brushes and associated wiring and connections.
Posted on Oct 30, 2010
Anonymous
SOURCE:
Anyone now the fault light codes for this model---thank you
Flashing Lights & Error/Fault code - Repair
www.how-to-repair.com/.../washing-machine-with-all-the-lights-flashing...
Oct 25, 2014 - Now there may be some variances for older models, but there are 3 main types of board listed ... Tagged under: Ariston, Creda, error codes, flashinglights, Hotpoint, Indesit ... And can someone please enlighten me, thank you.
Identifying Hotpoint or Indesit Error Codes - YouTube
? 6:46
https://www.youtube.com/watch?v=aud14I0Zu9M
Aug 29, 2014 - Uploaded by eSpares
If your machine is stopping with flashing lights or a error code on the ... Lights on Washing Machine How to Repair Hotpoint,Ariston, Indesit ...
Flashing Lights on Washing Machine How to Repair ...
Dec 15, 2015 | Hotpoint Ariston Aquarius WD420 Front Load...
Hotpoint Model WM75 Error Code E30 (Motor Drive problem)
what does e30 mean on wm75 hotpoint ultima 1200
Dec 02, 2010 | Hotpoint Washing Machines
My hotpoint washer/dryer keeps coming up with code e30 see user guid and stops washing,what does that mean
Error code E30 indicates motor tachometer failure.
There is a loss of signal during tumble or spin.
Check your user guide.
Dec 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
I'm getting an E30 error code just after the first
Dear customer,
                     Error 30 (on Hotpoint) just means the motor isn't working. Several things, including the power module, can cause this. The most common cause though is worn carbon brushes. There is also a 7.5 amp fuse on or near the power module, which can blow. This fuse is on the motor circuit to protect the circuitry of the power module. If it blows, then the motor won't work and you will get error 30.
If it has blown, it's likely to be caused by the motor. I had one last week where the armature in the motor had shorted to earth which blew the 7.5 Amp fuse.
To check the brushes, with the machine unplugged! Have a look at
http://www.washerhelp.co.uk/spare-parts-shop/hotpoint-carbon-brushes-faq.html
http://www.washerhelp.co.uk/spare-parts-shop/Hotpoint-carbon-brushes.html
Plz rate this solution.. thank you..
Apr 09, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error code e30 see user guide .comes on and stops washing do not have user guide
E30 is a motor problem which is most likely brushes need replacing.
Hope this helps & Thanks for using Fixya.
Jan 18, 2009 | Washing Machines
E30 error code
Error E30 is a motor drive problem. Would check motor brushes as most likely fault.
Dec 16, 2008 | Hotpoint Ultima WD72 Front Load...
HOTPOINT WD71 ERROR E 30
Hello john walker24
Welcome
You said, you have a Hotpoint Ultima 1200 Washier dryer model WD71s and keep getting an E30 error code after it fills with water.
Any idea what the problem is?
This is what Hotpoint tells us!
E30 = A motor drive problem has occurred.Try running the programme again.
If the problem persists call for a Service Engineer.
BUT, I will tell you to unplug the appliance for 5 minutes and see if this resets the system and solves the error code.
Sometimes it is only a glitch and you can reboot and be alright if there is really no mechanical failure!!
Let me know how it goes?
Huuum,
Please remember to leave a rating!
Thank You.
Waiting for your response!
Oct 01, 2008 | Hotpoint Ultima WD72 Front Load...
I have a hotpoint ultima 1000 coming up with E30 problem. can you help, I do not have a manual.
Jan 04, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WD71s
The e30 error code relates to motor drive problem. Open the service panel and look for a broken belt and does the motor spins. Let me know with your results if you will need for further assistance. Good luck!
Sep 08, 2007 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
251 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
