Open following link for Tork timer manuals and wiring diagrams
http://waterheatertimer.org/Tork-timers-and-manuals.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Tork 1100 series
Tork 1103 can control 120V or 240V Loads (fan light motor)
It can control 1 or 2 different Loads
Tork 1103 has 5 screw terminals
L 1 Unmarked X 2
The Tork 1103 has a 120V clock motor that consumes 3 Watts and costs $3.50 per year to operate.
1) You have to have a white Neutral wire from breaker box connected to Unmarked terminal no matter if you are controlling 120V or 240V Load
2) You have to have a black Hot wire from breaker connected to terminal L no matter what load
If you have 1 Load 120V:
Terminal L black hot from breaker
Terminal 1 no wire
Unmarked terminal white neutral from breaker
Terminal X black wire going to Load
Terminal 2 no wire
White wire going to Load connects to Unmarked terminal
So 2 white wires are on terminal 2
If you have 2 Loads 120V (Load1 Load2)
Terminal 1 jumper your black hot from Terminal 1
Terminal X black wire going to Load1
White wire going to Load1 connects to Unmarked terminal
Terminal 2 black wire going to Load2
White wire from Load2 connects to Unmarked terminal
So 3 white wires are on terminal 2
If you have 2 Loads 240V
Unmarked terminal white neutral from breaker (no other wires connect to this terminal)
White wire going to Load1 connects back to 240V breaker
White wire from Load2 connects back to 240V breaker
If you have more questions, add a comment and I will help
The asker wanted information on the 1104 timer. My old eyes got crossed and I saw 1103 timer. Let me give correct information. The 1104 timer is a 240V timer with 240V clock motor. The T1104 comes with 4 screws or 5 screws. The 4-screw 1104 can control 1 Load. The 5-screw 1104 can control 2 loads. For the 1 Load timer, Hots from breaker connect to L and 1 and hots to Load connect to X and 2. For the 2 Load timer, Hots from breaker connect to L and 1 and hot to load1 connects to X. Hot to load2 connects to 2. The Hot from load back to breaker connects to Unmarked terminal.
Do all common/neutral wires hook together
Yes, On the 120volt timer. If timer is 240V then there is no neutral wire:http://waterheatertimer.org/See-inside-m...
