KODAK ESP 7 AIO
Carriage stuck on left handside
Paper jam message but no paper or bits stuck inside
Have tried reset procedures of internet tried when -feed rollers turn but carriage cradle appears stuck and is prevented from traversing to the right ??
Found a comment about improper encoder reading
How do u correct optical encoder positioning error-by physical or electronic means or both ??
Cheers Lee
[email protected]
Turn the Printer on Wait for the error message open the printer move the ink cartridge a little bit to the right on the left side you have three gear wheels move the frontmost forward to move the printer carriage it should go easy. Close the Printer and press OK to test the printer. If it not works move the gear wheel further and further and maybe backwards to remove stuff which block the carriage
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
Turn off the printer and open it to see where the paper is stuck.
Manually move the carriage toward the opposite side.
Check the paper path and remove any piece of paper or any other object that is stuck in the path.
Go to kodak.com/go/itg and follow the step by step troubleshooting. If you still get the same error,Time to contact Kodak at 1800 421 6699 and Your printer will be replaced free of cost.
Turn off the printer and open it to see where the paper is stuck. Manually move the carriage toward the opposite side. Check the paper path and remove any piece of paper or any other object that is stuck in the path. Reconnect the power cord and turn on the printer. get more information and help from here.
If you are getting a 'carriage jam' error as soon as you turn on your Epson printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam' : Open Door, clear carriage jam, and then press OK to continue' error message Turn off the printer and open it to see where the paper is stuck. Manually move the carriage toward the opposite side. Check the paper path and remove any piece of paper or any other object that is stuck in the path. Reconnect the power cord and turn on the printer. http://www.fixya.com/support/t5192341-epson_photo_1400_paper_feed_ink
if there is a paper jam then open the rear access door and look for any paper or piece of paper stuck in there if not then try and roll the roller slowly to check for paper jam........if you still cannot find the paper then open the front access door as if you are trying to replace the ink cartridges and look inside if you can see any paper stuck in there or not........if still no paper restart the printer after 30 seconds and check if still getting paper jam or not............if yes then contact Kodak tech support.......
If you are getting a 'carriage jam' error as soon as you turn on your Kodak printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Fix 'Carriage Jam: Open Door, clear carriage jam, and then press OK to continue' error message Turn off the printer and open it to see where the paper is stuck. Manually move the carriage toward the opposite side. Check the paper path and remove any piece of paper or any other object that is stuck in the path. Reconnect the power cord and turn on the printer. http://www.fixya.com/support/t2952766-kodak_all_in_one_printer_paper_jam
