Webroot Spy Sweeper (spysweeper) for PC Logo
Posted on Oct 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Spy sweeper won't respond. The window opens but won't show anything to click. Hover over the symbol at the bottom of the screen it just says "loading..."
Anonymous
Level 2:
New Friend:
  • Expert 71 Answers
  • Posted on Oct 30, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
71
Questions
0
Helped
22139
Points
237
You have a virus affecting this program from operating properly. Just remove and reinstall the program.
Instructions:
1. From the start menu go to Control Panel.
2. Go to Add Remove Programs.
3. Remove Spy Sweeper.
5. Download and re-install the program.
Difficulty uninstalling webroot off my computer
Right-click on the Webroot Spy Sweeper icon on your computer's taskbar. A menu for the program will appear. The taskbar is the bottom bar of your computer. The Webroot Spy Sweeper icon looks like a green bulls eye.Select "Exit" from the Webroot Spy Sweeper menu. Select "Yes" if asked if you wish to shut down the program.Click on the "Start" icon and select "Control Panel."Click on "Add / Remove Programs" if you are using Windows XP. Select "Programs and Features" if you are using Windows Vista or 7.Click on the "Webroot Spy Sweeper" program listing.Click on "Uninstall." A Webroot Spy Sweeper uninstall wizard will open.Select "Uninstall" in the wizard and hit "Next." Follow instructions on screen.Restart the computer if prompted.Click on "Start" and select "All Programs."Right-click on the "Webroot Spy Sweeper" folder and select "Delete."
1helpful
Purchased new pc w/windows 7 os. installed spy
In order to solve this problem you have to solve this problem
you have to uninstall Spy Sweeper.before that you open taskmanager and in the process tab,click on the respective process of spy sweeper
and stop it.Then you could uninstall it from your pc.
Then install Spy Sweeper from your cd.
Compatability issue
On Feb. 12, 2008, Microsoft released an update that fixed the recent compatiblity issues between Windows Vista and Webroot Antivirus/Spy Sweeper that were a result of a previous Windows Jan. 8, 2008 update.
Recommended Fix:
To fix this issue, update your copy of Windows Vista with the latest updates available as of 2/12/2008. For many users, Windows Vista will update automatically at its next scheduled time, but the update is also available as a manual download. See below for instructions on how to update Windows Vista.
We also recommend updating your copy of Webroot Antivirus/Spy Sweeper. The latest version does not experience any compatibility issues and it is generally recommended that you update your software to the latest version in order to ensure maximum security and protection of your PC.
Click here for help on how to update Webroot Antivirus/Spy Sweeper.
How can i remove webroot spy sweeper with anti virus from my computer?
To uninstall Spy Sweeper :: let Microsoft Windows uninstall the software automatically.
1.clicking on the Start Button
2. Select Control Panel
3. Select Add and Remove Programs.
Occasionally this method will not work, and produce an error about not being able to uninstall the software. If this happens right click on the Spy Sweeper icon on the right hand side of the toolbar where the clock is located and select exit This will shut down the Spy Sweeper program. Next press ctrl + alt + delete which will open the Task Manager. Click on the Processes tab. Search for spysweeper.exe. If this process is running click on it then select end process. Repeat this step to search for and close the process WRSSSDK.exe. After this is done Spy Sweeper should be able to be removed by using Add/Remove Programs
2answers
Un installing syy sweeper
Your should try a free program called Revo Uninstaller www.revouninstaller.com/
After installing open revo and it will show you all the programs currently installed on your pc, double click on spy sweeper and follow the steps.
side note: some of the steps take a moment or two so be patient.
I have a subsription with McAfee and I cannot download the software before having this webroot spy sweeper removed.I cannot find it on my computer and never had a subscription with this webroot spy...
first uninstall the webroot spy sweeper through the following steps.
1.click start
2.go to control pannel
3.open 'add or remove program'
4.a window will open wait for some time until the list is populated
5 i)in that list find webroot spy sweeper and click remove
   go through the uninstall wizard and finish the uninstallation process
5 ii)if you didn't find webroot spy sweeper there then it can be a virus
You need to download a program called MalwareBytes because that searces your entire computer
, finds the virus and completely destroys it.
http://www.download.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html
Click the green 'download now' button (don't worry - this is free) and once you've downloaded it, got the updates and done a system sweep which takes a long time but it's worth it, you should be fine. It also solves the desktop, wallpaper and screensaver hijack, too.
6. restart your computer
7.open mycomputer click search and do a search for webroot spy sweeper
delete all the files and folders regarding webroot spy sweeper
8.now download mcafee before installing mcafee uninstall MalwareBytes and restart your pc
because at a time only one antivirus software should be used
i think this solution will help you
if the problem is not fixed please inform i will suggest some other ways
1helpful
Uninstall
Hi Jeli
most effective way to uninstall Spy Sweeper is to go to Control Panel and then select Add and Remove Programs. In this case, you may try to follow the instructions below.
1.right click on the Spy Sweeper icon on the right hand side of the toolbar where the clock is located and select exit
2. press ctrl + alt + delete which will open the Task Manager.
3. Click on the Processes tab. Search for spysweeper.exe. If this process is running click on it then select end process.
Keep me posted.
Thanks.
Webroot Spy Sweeper
How are you connected to the internet?
Spy sweeper not working
1- Install using this serial: SSDC-ONLN-AAAA-NNNL-NINC
Then
2- Go into the C:\Program Files\Webroot\Spy Sweeper
Then
3- Right click the "install.dat" file-->go to Properties--> at the bottom check the boxes "read-only" and "hidden"-->then click Apply
And finally....
4- Run SpySweeperFix.v1.1.exe
Allow SpySweeperFix.v1.1.exe to run on the next Windows start up, this gives you the definition update till 2020, otherwise, you'll just get till 2006!
Hope this helps, if not, post back.
Spy problems
First Try This:
Try to uninstall Spysweeper and reinstall (Control Panel -> Add Remove Programs)
If it gets nasty reboot in to safe mode (follow these steps):
1. Restart your computer and start pressing the F8 key on your keyboard. On a computer that is configured for booting to multiple operating systems, you can press the F8 key when the Boot Menu appears.
2. Select an option when the Windows Advanced Options menu appears, and then press ENTER.
3. When the Boot menu appears again, and the words "Safe Mode" appear in blue at the bottom, select the "Windows XP with networking"
Once you are in safe mode do this:
1. Download the free microsoft app "Autoruns" from http://download.sysinternals.com/Files/Autoruns.zip
2. Extract the .zip file
3. double click the file "autoruns.exe"
4. The program will start autoscanning your computer to see what boots up with it (it will take a few min.... bottom left of screen tells you when it is done)
5. Make sure you are in the "Everything" tab (which loads up by default)
6. Hit CTRL + F (to do a Find)
7. Type "Spy" and hit ENTER
8. The first entry containing the word "Spy" in your startup instructions will be highlighted
9. Look at the "Image Path" column, if it contains anything like "C:\Program Files\Webroot\Spy Sweeper\" uncheck that item
10. Press F3 to see the next item containing the word "Spy"
11. Keep repeating steps 9 & 10 until you get through the entire list
I'm guessing you might find the following:
C:\Program Files\Webroot\Spy Sweeper\SpySweeper.exe
C:\Program Files\Webroot\Spy Sweeper\SSU.EXE
C:\Program Files\Webroot\Spy Sweeper\SpySweeperUI.exe
12. Reboot as normal (spysweeper should not load up)
13. Attempt uninstall, reinstall again
Top Webroot Computers & Internet Experts
Mike 'H'
Mike 'H'
Level 1 Expert
ADMIN Andrew
ADMIN Andrew
Are you a Webroot Computer and Internet Expert? Answer questions, earn points and help others
