Hi, problem can be solved. The problem can be from two places,
From the speaker and,
also the cross over.
I might be from the speaker if the wire connected from the cross over inside the speaker has cut or has removed.,it can make the speaker (15),not to make any sound..
The cross over might also be the fault too. The cross over is located inside the speaker and it makes the 15 speaker makes sound..
'There are capacitors on the crossover that control and makes the 15 speaker make sound.If the capacitor gets damaged it can make the sound stop. Also you will need to check the fuse inside the speaker, you will find the fuse on the cross over of the speaker.
Troubleshoot the above, and problem solved,...
Hope that helped..
Thanks fro using fixya.....
