Http://www.electricmotorwarehouse.com/PDF/polaris_manual.pdf
If you goto this link and scroll down to page 4, it shows what the wiring is.
Hope this helps. If so, please rate me for this.
SOURCE: looking for wiring instructions for the
The diagram on the side of the pump shows how it sould be wired for low volatge. I'm having a problem wiring for high volatge and posted the diagram. Use the link to access.
http://www.poolspaforum.com/forum/index.php?showtopic=19400
SOURCE: my polaris PB4-60 booster pump does not turn over.
I was able to save a service call by doing the following in under 8 minutes:
1.Switch off electric to pump.
2. Turn off valve on supply side of pump so water does not flow during this procedure.
3. Turn offf filter.
4. Unbolt the six bolts (1/2" socket) on the front side of the pump.
5. Carefully separate the pump from the front panel which contained the six bolts.
6. Grasp with both hands the black round thin disk (impeller) which is part of the pump and turn it either clockwise or counter clockwise. It may be slightly difficult initially but once it it freed it will move easily.
7. Reassemble.
8. Open valve and turn on filter and the power to booster pump.
Any questions e-mail me at [email protected] good luck
SOURCE: Just bought a new polaris booster pump (PB4-60)
Have you checked for voltage at the pump motor? Did you wire it correctly? Is the motor 110V or 220V. Did you match the motor to your existing voltage?
SOURCE: where are the wires to attach comming from the hou...
Under the back cover is where the wires attach.
Do you know what you are doing? Do you know the difference between 120 VAC and 240 VAC? Do you know what your pump is wired for? Do you know the line voltage coming into your outlet where you will plug in the pump or hard wire it into??
No guessing is allowed here. Death is a possibility. Be sure what you are doing before you touch anything. If not sure, pay an electrician to make this connection.
What about bonding ... does your pool require bonding? Is it bonded? Please check on these things before you begin using your pool.
Thanks for your nterest in FixYa.com
THanks so much you turned that into a 30 minute DIY project!!
