RTO Weed Eater Electric Barracuda 2595 Leaf Blower Vac Bag Logo
Posted on Oct 29, 2010
Looking to replace my vac, bag if possible - RTO Weed Eater Electric Barracuda 2595 Leaf Blower Vac Bag
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
213
Points
Http://www.ereplacementparts.com/vacuum-bag-kit-fits-types-p-229821.html
I need a Vac bag for this unit
Hey, this is Jeremy with Crucial Vacuum,
Unfortunately, you did not specify what type of vacuum you were looking to get replacement bags for. I have attached a link to the Crucial Vacuum website where you might be able to find the right type of bags you are looking for.
http://www.crucialvacuum.com
You can purchase replacement bags, filters, and accessories for a wide range of vacuums direct from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10. We strive to provide our consumers with the lowest possible prices and believe that you will be very happy with what you find.
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 18, 2015 • Vacuums
1helpful
2answers
Need replacement bag for sears chipper vac model 9877799601
Call Fred at 651-786-4277 I have used bags and some new bags. I also refurbish chipper vac bags
Bag needed changing there was no burn ing smell or strange noises before i changed bag after bag was changed it wouldnt start. the cord is new no fraying and vac is about 5 years old. didn
I'm not real experienced with this model vac, but I do know that many of the newer vac's are being manufactured with a small button or lever, whatever the particular brand of vac decides would best fit on their unit, that would be located somewhere around the edge of the bag door opening and would need to be depressed by having a bag inside in order for the machine to run. I would check for something of this nature to be sure that during the bag change that you didn't just miss putting it in quite right to depress the go button. Other than that, it's entirely possible that the switch died. If that's the case you'll need to bring it in to a vac repair shop for help.
2helpful
We just moved in - the house is about 9 years old. I have a Eureka Mega Boss central vac - looks like model # is CV20220. 12.4 amps, 120 volts. Can't figure out what type of bags I need. Can you...
Well, for this unit you will need any of the following bags,
Eureka genuine Part# 90610
Eureka replacement (Central vac bag)
another genuine bag style called CV-1, and/or CV-2
Kenmore Central vac bags
Most of the bags there are available at your local vacuum shop, and sometimes even Sears. The Kenmore central vac bag is, can and will fit your Eureka Mega Boss. Prices range on these bags anywhere from $12-$20 for packages of 3. Generally you will replace a bag once every 3-4 months.
Good luck,
Mark
Nov 10, 2010 • Vacuums
Electrolux Model 2100 vacuum won't work
hi from uk may i suggest you remove cover and the new dust collection bag then if you look in the bag compartment there is a gauze filter fitted usually grey in colour ? at opposite end of compartment where bag connects this gauze filter is the outlet from bag compartment that the air exhales when vac is operating ie as vac **** up dust into bag the bag has microscopic holes that allow sucked up air and dust to collect but keeps dust from passing into bag chamber but allows air to escape thro holes and so enter bag chamber then escapes via the gauze filter to outside of vac hope you follow this ?? now if this filter is blocked/never been cleaned/changed ? then the symptoms of indicator bag full light will come on you can remove and wash filter if it is gauze typ? dry and refit then try vacuuming ? or replace filter they are not expensive usually in pack of 3 in uk DO NOT RUN VAC WITHOUT THIS FILTER FITTED ! or you will have some dust in the room ? hope this helps?
The bag indicator shows full but the bag is empty
In my bag vac, I have found that when the light shows the bag is full when its not that there is something between where it sucks into the vac to where it empties into the bag...maybe cat hair, dog hair....etc. Try removing the bag and running it, this may allow the air to flow alittle faster and force out the jam. You may also try removing the bottom of the vac, usually just a few screws, and checking to see if you can see the jam. What is happening is this jam is slowing down the air flow and the vac thinks the bag is full....also check the filter where the air leaves the bag area...also look where the bag connects, sometimes trash can hang there.....good luck
6helpful
3answers
My electrolux vac shut off for a full bag. After replacing the bag the vac won't start and the bag full light stays on.What should I be looking for to resolve my problem?
If the suggestion that renevacdoc did not work, it is most likely that your valve assembly(full bag control) has gone bad and needs to be replaced. You will have to take your vac to the Aerus/Electrolux dealer/service store for repair.
Joe
2answers
Looking for a leaf bag replacement for a 4.5 HP craftsman yard vac model no. 247.770100
Sears has a great online site which you can get parts for almost any make and model equipment.
Here is the link
SearsPartsDirect.com
Replacement bag for Ryobi blower/vac
http://www.ryobi.com.au/ within this web site if you look under service outlets gives you the stores that are closest to you that sell ryobi equipment i looked and found dubbo mowers and chainsaws ph 68823122 they might be able to find one for you hopefully bestaluck glenn
Nov 15, 2008 • Garden
The vacuum isn't picking anything up. Nothing is getting in the filter. Dirt is just being redistributed back onto the carpet.
hi from uk if you could please verify what type of vac you have ? upright with dust bag? of dyson no bag? or is it a cylinder vac with flex hose? it would helpto advise on possible cause of vac not working and possible remedy ?
Oct 31, 2008 • Vacuums
Top RTO Garden Experts
Sean Wright
Sean Wright
Jay Finke
Jay Finke
ADMIN Andrew
ADMIN Andrew
Are you a RTO Garden Expert? Answer questions, earn points and help others
