The 10, 59, 90 and 99 error codes indicate that a Noritz heater has experienced a combustion abnormality. In most cases, it is the result of an obstruction in the heater's flue. Examine the flue to see if it is blocked by debris and clean if necessary.
Noritzhttps://www.noritz.com > Blog
Nov 16, 2015 - This error code involves a breakdown in communication between two tankless water heaters using the Quick Connect Cord. It can occur when more ...
For a Noritz tankless water heater, error number 78 indicates a problem with the fan motor. The instructions below will help you clear the problem number 78 on a Noritz tankless water heater:
Turn off the power to the tankless water heater by either disconnecting it or switching off the circuit breaker.
Verify that the fan motor is clear of any obstructions or debris that may be preventing it from operating properly.
Check the fan motor is receiving power by measuring the voltage across the fan leads with a voltmeter. Verify that the electrical connections to the fan motor are secure if there is no voltage.
If the fan motor is broken or not operating properly, it may need to be replaced. For further assistance with the repair or replacement of the fan motor, you can contact Noritz technical support or a certified HVAC specialist.
After resolving the issue with the fan motor, switch off the power to the tankless water heater for at least 30 seconds before turning it back on. This will clear the error code and restore normal operation to the device.
If you are unclear or uncomfortable with any of these processes, you should seek the aid of a certified HVAC specialist or Noritz technical support.
The Noritz Manual shows fixed for the following error codes:
11
21
90
99
For all other codes this is the recommendation:
Contact our sales agent if:
• Any other error code appears.
73 code is a circuit board error. It typically occurs if you connect or disconnect anything in the heater with power on. Try disconnecting electricity for 20 seconds to reset the unit. If the problem continues, you may need to replace your circuit board.
The trick with these hot water heaters is to keep the filter screen clean and flush the system with CLRperiodically. Code 11 is ignition error. Is your gas valve turned on?
I called Noritz error code 16 is a overheat problem. Noritz say's to flush your coil with vinegar or CLR.
Use a small pump to recirculate the CLR or vinegar through the system for 45 minutes and flush with fresh water. This worked for me.
