These operations are clearly defined in the manual what was sent with the inverter originally. If you no longer have the manual, contact the company that you purchased the controller from and request a replacement manual.
Assignment of Interface Pin 1 not used, Pin 2 TxD Transmitter Signal/RS232, Pin 3 RxD recever signal/RS232,
RS 232 cable part number 00.58.025-001D Length 3 meter
(9 pins SUB-D Female) 2--------------------2 (9 pins SUB-D male)
3--------------------3
5--------------------7 Must be use the shielded cable & one side body connect with shielde
I think its will work
Hello!
What shall I do to communicate with a Combivert F5. I have tryed with different cables without success.
RPN/ Sweden
Forward CONtinues
System is at the commanded speed in the forward direction.
