Navigon 7200T GPS NAVIGATOR PERPW/ FREE TRAFFIC VOICE ENTRY  Logo
Trish Voorhies Bunce Posted on Oct 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Volume up all the way not muted but not speaking?
perdue40
Level 3:
  • Master 589 Answers
  • Posted on Oct 30, 2010
perdue40
Master
Level 3:
Answers
589
Questions
0
Helped
122146
Points
1317
Not sure it this is like my Nuvi but you have to select a Language with ( TTS ) ending that is Text-To-Speech .... other i aw were i thnk something that says ( Eesti )
But it should be in the Language setup
My callers cannot hear me
Check to see if you have it on mute. Go into your menu options and under sound hit ok It should show master volume, keypad, earpiece,speaker try master volume then volume up .
2answers
Nuvi2550 has no audible voice prompts
have you cked if it is muted? touch the speaker and when the volume control comes up you can see if it is muted
Dec 05, 2011 • Garmin GPS
1helpful
I can hear callers but they cannot hear me. Mute is not engaged,
Please see the link below for the User's Guide.
• Headset is muted. Long press (3 sec.) the volume down button on headset to unmute the microphone. See page 16.
• Improper positioning of voice tube. Try various other positions.
• Voice tube may be clogged. Remove voice tube and test to see if callers can hear you without it. If they can, then replace the clogged voice tube. See page 18.
• Speaking volume is too low. Increase the speaking volume by
adjusting the speaking volume minor adjust buttons on the base unit as described on page 16. If the volume is still too low, select another speaking volume major adjust setting as described on page 16.
• Incorrect configuration dial setting for your phone. Try other
phone configuration dial settings on the base unit. Ensure the
selected number is in line with the position indicator. See page 14.
Plantronics CS70 User's Guide
Good luck from Headsets Direct!
I have a Nuvi 650 which seems to be muted. How do I get it to talk again?
1.
  • Press the volume, the speaker icon at the bottom right of the screen showing WHERE TO and VIEW MAP
  • On the volume screen there's a tick box for MUTE. If it's ticked press it and the tick will be removed. The satnav should then not be muted.
2. If this doesn't solve the problem it may be that the voice file is corrupted.
  • Press TOOLS
  • Press SETTINGS
  • Press LANGUAGE
This brings you to a screen with VOICE, TEXT LANGUAGE and KEYBOARD
Press VOICE and select another English speaking voice. This may solve the problem.
3. If you don't have another English speaking voice;
  • Download the latest version of Webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27 and install it to your computer
  • Connect your satnav to your computer and run the Webupdater program
  • Webupdater will find any software updates for your satnav. Install them. When the installation is complete it will find optional updates including voices. Select some English speaking voices and download them to your satnav.
  • After you have disconnected your satnav from the computer you'll need to select a voice again as described in paragraph 2 above.
2helpful
One channel muted until the volume is turned up
This problem is usually dur to some corrosion in the speaker relay. If the relay can be opened, burnish the contacts and you should be OK. The higher volume creates a higher voltage that can "jump the gap" so to speak. Once the connection is made it will remain. That is why lowering the volume will work.
Dan
The speaking part just stopped speaking. Is there something Iam doing wrong? The volum is up 100% but nothing happens as far as the speaking voinc on the Garmin.
check that you have not activated MUTE and also go to settings and select another voice be sure to select a TTS (text to speech)
Please rate my help++++Thanks for using FIXYA
Hi when i speak with the microphone i dont lisnt to my voice i think its a problem with my voice card i have a dell6400 is there a solution for that
Everything may be working fine except the settings. Click open the Volume icon from the system tray and check if the mic is muted (most likely it is muted as Windows has a habit of muting it on its own). So, unmute it abd listen to yourself.
1helpful
2answers
Why i cant talk in headphone i can hear the voice in computer. i installed nymgo talking internationally i can herta the voice but i cant speak the speaker placed in my mouth does not have voice
Click on start->control panel->sounds and audio devices->audio tab->under sound recording click on volume tab and uncheck mute all and anyother mute.
Issues with sound not speaking with computer. It
In the mixer/volume, are any of them muted at all? When you try playing music or a video, does it give an error?
Volume
Go to the control panel and make sure the sound properties are correct. Make sure the volume isnt muted. Go to the Device Manager and make sure the sound driver is present under Sound, Video and Game Controllers.
You need a little more description than, 'no volume coming to speaks'. What have you tried so far?
Make sure the cord is plugged into the proper jack....the pale green one...
Top Navigon GPS Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
Are you a Navigon GPS Expert? Answer questions, earn points and help others
