I have a customer with a goodman furnace,she has propane gas now she is switching over to natural gas,does the goodman furnace make a conversion kit or does she need new furnace..thanks bob...
Parts Town Canadahttps://www.partstown.ca > Anets
Find OEM Anets B8043803-C Gas Conversion Kit, Propane to Natural Gas, SLG40 replacement part at Parts Town with fast same day shipping on all in-stock ...
You will need to get a natural gas conversion kit for your equipment. It will include around three different orifice sizes depending on elevation. Never drill orifices yourself as this is a gas appliance and could kill you. You will have to remove your gas manifold and unthread the existing orifices and screw in the new ones. As far as the gas valve you will need to unscrew and remove the adjustment screw and change the spring located underneath and reassemble. Once changed out you will need to check the manufacturers name plate and adjust the manifold pressure using a manometer. If this is not done having incorrect gas pressure can cause delayed ignition, overheating of the heat exchanger or high carbon monoxide levels. The conversion kit is inexpensive and should take less than an hour to do
Apparently, Weber does not make a conversion kit to convert the grill from propane or from natural gas to propane. According to the Owners Manual - "Liquid propane gas is not natural gas. The conversion or attempted use of natural gas in a liquid propane unit or liquid propane gas in a natural gas unit is dangerous and will void your warranty." (From Page # 3 of the Owners Manual)
Most furnaces come from the factory set for natural gas. If you contact the manufacturer to find the local distributor for thatparticular unit . you should be able to order a propane conversion kit. The kits are very easy for a trained heating guy to convert. A good handy man should be cable to do this changeover. BUT the manometer that is needed to properly calibrate the gas valve is not worth the purchase price for one application. I recommend that you use a trained heating guy.
Yes, goodman offers a kit. However you will need a gas technician adjust the pressure for you. The whole conversion will take about an hour. The kit may cost $50 and labor is anyone's guess. Call your gas company and give then the model and serial nimber. They can order it and install it.
