Samsung BD-UP5000 Blu-ray and HD-DVD Player Logo
Posted on Oct 29, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My blue ray sound will not come on but the sound works of tv programs
Anonymous
Level 3:
President:
  • Master 635 Answers
  • Posted on Oct 29, 2010
Anonymous
Master
Level 3:
President:
Answers
635
Questions
0
Helped
262436
Points
1837
If you are using an HDMI cable make sure that your sound is not set to SAP initially. I usually test this by setting the TV to stereo to begin with and troubleshooting from there. The other option is to use the audio out cables provided with your player and plugging those into the red and white RCA jacks closest to the HDMI port.
I have a new panasonic tv a sony blue-ray player and bose sound bar. Freeview works fine. However there is no audio when using the blue-ray which is connected via HDMI.
It is possible that you have not got the right sound settings for the blue-ray or other equipment. Check that each device, especially the blue-ray is outputting the sound via the HDMI. Look at the sound settings using the remote for each device. The best sound is often obtained by using an optical lead. So if your devices have the connections for an optical lead, buy one of them and enjoy the superior sound of the blue-ray. HD channels on Freeview also offer Dolby sound, which you can get with an optical link better.
2helpful
How to connect Blu ray disc player with my Bose 321 system. I have 1080 p samsung LCD TV. How to get the best.
hi,
do the following.
1. connect ur blue rays hdmi out to ur tvs hdmi input.
2. connct blue rays out to any one of the coaxial(aux) input of bose.
3. connect ur tvs optical audio output to optical audio input of bose
4. connect monitor out of ur bose to any one of ur av in of ur tv. connect component video to better quality .
4 . in the blue rays audio setup select audio output priority as optical/coaxial
5 . in bose set aux as digital input.
to see blue ray select hdmi of ur tv, sellect in bose in which the blue rays coaxial is connected(aux) insert disk in blue ray an watch
to see dvd in bose select tvs corresponding input, select bose to dvd . insert dvd and watch
to whach tv program set tv to corresponding mode. set bose to optical audio input mode.
ok
I just got a Samsung Blue-ray disc player program the remote
need code to program the remote for my bd p1590 to control my panasoniic hd tv and the codes that are in the manual dont work
1helpful
8' Optical Cable from TV to Receiver and Signal is Breaking Up
Before you buy anything try checking the AUDIO Settings in the Menu of Each Device (Mostly TV) and see if they are set to PCM or BITSTREAM. HDMI is mostly set to PCM while Optical is generally Bitstream. The TV may be set to the opposite of what it needs to be. I would try to get PCM to work first cause it is Better, If not then set what you can to Bitstream and it should pass. Also check in TV Menu for SOUND OUT or AUDIO OUT or SPEAKERS. Some TV's have a problem passing Audio through when they are already Outputting them to it's own Speakers! I Hope this Helps out!
1helpful
The Yamaha RX-V463 AV does not playsound from the blue ray player
"I am also having difficulties in try to display the yamaha set up menu on the tv."
According to the manual the display menu for TV will not work with HDMI hook up.
I also have a Panasonic HD TV and can't get TV sound through my Yamaha AVR on "TV Sound" mode.  Trying to use HDMI cable for this also.  Do I need a digital optical cable or do I not have something set right?
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
