All right, this can be a bit confusing. IF you still have the cup that came with your Rice Cooker, use it to measure your rice. Then, inside the cooker there are lines showing how much water to add based on how many of the Zojirushi measuring cups you used of rice. THAT's simple.
IF you DON'T still have your Rice Maker measuring cup you will have to use a 3/4 cup U.S measuring cup. This equals the same amount as the rice cooker cup. For each 3/4 cup of rice you use, add that many cups of water. If you use 3/4 cups of rice twice, then add water to the 2 line.
In other words, a rice cooker measuring cup equals 3/4 cup of regular U.S measuring cups.
Hope I didn't confuse this too much. I hope this helps and if it does, please let Fixya know by rating my solution. Good luck and happy cooking!
To cook rice, fill center basin of base with water. Place the rice bowl
on basin. Add rice and water as follows. For white rice add water in a
1:1 ratio to rice plus 1/2 cup. For brown rice add water in a 1:1 ratio
to rice plus 3/4 cup. Examples: 1 cup white rice, 1-1/2 cup water; 2
cups brown rice, 2-3/4 cups water. Put lid on and plug in and in about
50 minutes you should have delicious rice.
hello there here it is pretty simple ok Use a 1:1 ratio of rice to water plus ½ cup of water for white rice and a 1:1
ratio plus ¾ cup of water for brown rice. hope that is verry helpfull best regards michael
I have a Toastmaster 3 cup rice cooker but think the ratio would be the same.
Long grain white rice - 2 rice measuring cups - water to 2 cup line = 8 (1/2 cup) servings
3 rice measuring cups - water to 3 cup line = 12 (1/2 cup) servings
Long grain brown rice - 1 1/2 Rice measuring cups - water to 3 cup line - 6 (1/2 cup) servings
For fluffy rice: After cooker shuts off, allow rice to stand for approx. 15 minutes, covered, before serving.
hope you have figured out the ratios but in case you haven't--here are the ratios. The white rice is measured by 3/4 cups. I put three 3/4 cups of white rice in the cooker then add water to the number 3 line--this works great. I had misplaced the rice cooker measuring cup for about a year but found it this morning and sure enough it is the same as 3/4 cup. good luck
