When inverters go bad this way, it's usually a diode that's broken down. They're easy to test with an ohmmeter- you will get an open reading one way (reverse biased), and will read a few hundred to a couple thousand ohms the other way (forward biased). Other than that, the other components will have to be troubleshot.
A transformer ot power transistors will have to be checked out. You can google articles that explain how to check them, if needed.
Good luck, and hope this helps.
Front power distribution box
The front power distribution box is
located in the engine compartment.
The power distribution box contains
high-current fuses that protect your
vehicle's main electrical systems
from overloads.
Passenger compartment fuse panel
The fuse panel is located on the right hand side kick panel. Remove the
panel cover to access the fuses.
To remove a fuse use the fuse puller tool provided on the fuse panel
cover.
Rear power distribution box
The rear power distribution box is
located in the luggage compartment
under the spare tire well cover. The
from overloads.
